Hi all
I try since begin of this year to transfer my OH2 into OH3 and want to use the new features in the habpanel.
In yaml, ofcourse also in the new system I’am a novice.
To implement a slider I have created a widget with samples from “Widget for yeelight pendant lamps” and another widget for the background image, sorry that I forgot the name
My problem is now, How can I change the colour of the text in the header and make this bold?
Here I want to change the colour to white when the prop for the picture is filled
Hope that somebody can help.
I’am pretty sure that within this code are a lot of unneccessary stuff, but remain that I try to learn how it works
and here is the code
uid: Dimmersimple_V3
tags: []
props:
parameters:
- description: Header text
label: Header
required: false
type: TEXT
- context: item
description: Brightness
label: Brightness
required: true
type: TEXT
- description: Background image, located in static/ folder
label: Background image
required: false
type: TEXT
parameterGroups: []
timestamp: Jan 14, 2022, 4:55:29 PM
component: f7-card
style:
background-image: "=props.bg_image_url ? 'url(/static/' + props.bg_image_url + ')' : ''"
background-repeat: no-repeat;
background-size: cover
background-brightness: 60%
slots:
default:
- component: f7-card-content
class:
- display-flex
- flex-direction-column
- justify-content-flex-start
- align-items-center
style:
height: 175px
slots:
default:
- component: f7-row
style:
position: absolute
slots:
default:
- component: f7-block-header
slots:
default:
- component: Label
fontSize: "42"
fontWeight: bold
color: red
text: =props.header
class:
- no-padding
style:
height: 100%
margin-top: 2px
width: 100%
slots:
default:
class:
- display-flex
- justify-content-flex-end
style:
animation: f7-fade-in 300ms
height: 60%
margin-top: 10px
slots:
default:
- component: f7-row
class:
- display-flex
- justify-content-space-between
style:
margin-left: -10px
width: calc(100% + 20px)
- component: f7-row
class:
- display-flex
style:
margin-left: -10px
slots:
default:
- component: f7-icon
f7: sun_min
style:
color: var(--f7-block-header-text-color)
- component: Label
style:
text: =items[props.brightness].state + "%"
- component: f7-row
class:
- display-flex
- justify-content-center
style:
width: 100%
slots:
default:
- component: oh-slider
color: white
item: =props.brightness
label: true
style:
--f7-range-bar-active-bg-color: rgba(246,246,0,0.5)
--f7-range-bar-bg-color: linear-gradient(to right, rgba(169,169,169,0.8), rgba(246,158,81,0))
--f7-range-bar-border-radius: 10px
--f7-range-bar-size: 18px
--f7-range-knob-box-shadow: 0 2px 4px rgba(0, 0, 0, 0.3)
--f7-range-knob-size: 20px
--f7-range-label-text-color: black
width: 100%
z-index: 99 !important
class:
- display-flex
- no-padding
- no-margin
style:
background: white
border-radius: 50%
border-top: '=items[props.brightness].state > 0 ? "none" : "2px solid #ddd"'
bottom: 10px
box-shadow: "inset 0px 1px 2px #eee"
height: 40px
left: 10px
position: absolute
width: 40px
slots:
default:
class:
- no-margin
style:
animation: '=items[props.shutdowntimer].state.split(" ")[0] > 0 ? "skeleton-effect-fade 2s linear infinite" : "none"'
background: '=items[props.brightness].state > 0 ? "rgba(124, 252, 0, 0.5)" : "transparent"'
border-radius: 50%
box-shadow: '=items[props.brightness].state > 0 ? "0 0 20px #fff, 0px 0px 30px rgba(0,255,0,0.5)" : "none"'
height: 100%
position: absolute
transform: '=items[props.brightness].state > 0 ? "scale(1,1)" : "scale(0,0)"'
transition: transform 0.2s
width: 100%
style:
background: rgba(255,255,255,0.8)
border-radius: 50%
height: calc(100% - 10px)
position: absolute
width: calc(100% - 10px)
- component: oh-link
action: toggle
actionCommand: '=items[props.brightness].state > 0 ? "OFF" : "ON"'
actionItem: =props.brightness
iconF7: power
iconOnly: true
iconSize: 17
style:
backdrop-filter: opacity(88%)
background-color: "#f7f7f7"
background-image: "linear-gradient(135deg, #f7f7f7, #e7e7e7)"
border: solid 2pt white
border-radius: 50%
box-shadow: 0px 3px 8px
color: "#a7a7a7"
text-align: center
