this is for the openhabian Pi.
If you want to adres GPIO pins on a remote Pi you can use MQTT like here https://community.openhab.org/t/controlling-a-raspberrypi-gpio-pin-with-mqtt/40912?u=kees_van_gelder
Hi. I want to read an analog input. My hardware is a beaglebone black. I could read it from linux but not from OH2. I tried to add an item like this:
Number AIN5 “Analog Input 5” { AIN5=“ANALOG_IN:5” }
but it didn’t work.
from linux I put this “cat /sys/bus/iio/devices/iio:device0/in_voltage5_raw” and I can see the value.
I have no problems with DI’s and DO’s using contact and switch with GPIO bindings.
Any idea? Someone can help me? Thanks
There is no specific binding for analog values afaik.
But what you can do is read the value of /sys/bus/iio/devices/iio:device0/in_voltage_raw and either MQTT that to openhab OR use the REST API to put it in openhab.
This is simple to do with Python.
If you dont know how, have a look at how the DS18B20 or DHTx transfers their values with a python program, it basically comes down to reading the file, parsing it to get just the one value you need and then use MQTT or REST.
REST API uses:
requests.put('http://192.168.xxx.yyy:8080/rest/items/<YOUR ITEM>/state',value)
Maybe this tutorial can help you on your way Reading a DHT11/22 with 'overlay' and send result via REST API
Thanks. I dont know anything about python but I will try it. Thanks again
its good to try, in order to learn. if you really don’t manage, call on me again
I’m trying to trigger a relay with this but the relay just stays on all the time. Any ideas what could be causing this?
do you mean you cannot switch it off?
I had wired it up incorrectly - thank you though.
great. Sorry my earlier reply might have been late but I was on holiday
What if I want to control the LED with a script? Is this possible while using this binding? I want to write a script that turns off the normally on LED when the state of a thing changes.
Hi
Would you happen to know if this process is purely for Raspberry Pi, or can I try it on any Linux based SBC?
(In my case, an ODroid C2 or XU4)
Cheers
@MDAR I don’t know about support from the GPIO binding, but you could maybe use my MQTTany. Currently the GPIO module only supports RPi but can easily be modified to support other boards if there are Python 3 libraries available to control their GPIOs.
Let me know if you are interested and if you already know of any Python libraries.
Thanks Michael.
I have limited knowledge of anything outside of GUI things.
So python is outside of my skill set.
Thanks for the offer.
No I mean I would make the changes. Looks like there is a library. I’ll get to this next, I’m just working on a module for DS18x20 sensors right now. Keep an eye on the github for the odroid support getting added.
I don’t know Python that well either, but when you can see an example of how simply it is, it makes life easier
So if you want to control the LED via a script, create a simple python script to turn off the LED. Then use the exec binding to call the script in a rule when the state of something changes.
Say you had the LED controlled via GPIO pin 25. First I’d assume (hope) you would be controlling that LED light via a transistor (like a Darlington TIP120 and 220ohm resistor to protect the pin) After installing python (plenty of articles on how to) then you’d create a script that would look something like this:
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(25,GPIO.OUT)
GPIO.output(25,False)
GPIO.cleanup()
Save to for example: /usr/local/share/gpio25.py
To test execution, simply type this from the command prompt:
python gpio25.py
Your LED should turn off.
If you want to turn on, you can simply send ‘True’ to the GPIO.output command rather than ‘False’ in the script above.
Thank you! It was really easy yes
Hi, thanks for this great and simple example.
I am just wondering, if the GPIO Binding is not yet available for OpenHAB3?! Is there any alternative?
Patrick
you may find this recent post interesting
yes, I do! I will test the binding within the next days and will let you know how it works! thank you
