I’m not sure what are you trying to accomplish by adding parameters to the script. I’m not using, nor I’m parsing any parameters when the script is being called. Just make sure that you run it manually first time, so you can give a permission for accessing a calendar. And use
I ran it without any paramters firstly, but the script told me:
Your browser has been opened to visit:
https://accounts.google.com/o/oauth2/auth?scope=https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fcalendar.readonly&redirect_uri=http%3A%2F%2Flocalhost%3A8090%2F&response_type=code&client_id=Xxxxxxxxxxxx-sse0n5dq6ti7nld5je9xxxxxxxxxxxx.apps.googleusercontent.com&access_type=offline
If your browser is on a different machine then exit and re-run this
application with the command-line parameter
--noauth_local_webserver
That’s why I made the next attempts with --noauth_local_webserver, which is the only way to be prompted for credentials
There is no use of the parameter, because script doesn’t parse it. It would make sense if that was included in the script. Do you have any way on running it in a browser on the same machine OH is installed?
Actually if I remember correctly I had to add this parameter to the script so that I could use the alternate oauth method on my headless Linux install that I can’t run a web browser on.
Thanks @Mike_Bagdanoff this worked for me.
But here is the next problem. I get errors in openhab.log:
2017-04-26 07:45:00.865 [INFO ] [pse.smarthome.model.script.GoogleCal] - Traceback (most recent call last):
File "/etc/openhab2/scripts/CalSyncHAB/CalSyncHAB.py", line 126, in <module>
Main()
File "/etc/openhab2/scripts/CalSyncHAB/CalSyncHAB.py", line 30, in Main
Credentials = GetCredentials()
File "/etc/openhab2/scripts/CalSyncHAB/CalSyncHAB.py", line 23, in GetCredentials
AuthenticationFlow = client.flow_from_clientsecrets(S.CalendarClientSecretFile, S.CalendarScope)
File "/usr/local/lib/python2.7/dist-packages/oauth2client/_helpers.py", line 133, in positional_wrapper
return wrapped(*args, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/oauth2client/client.py", line 2125, in flow_from_clientsecrets
cache=cache)
File "/usr/local/lib/python2.7/dist-packages/oauth2client/clientsecrets.py", line 165, in loadfile
return _loadfile(filename)
File "/usr/local/lib/python2.7/dist-packages/oauth2client/clientsecrets.py", line 125, in _loadfile
exc.strerror, exc.errno)
oauth2client.clientsecrets.InvalidClientSecretsError: ('Error opening file', u'OH2Auth.json', 'No such file or directory', 2)
rule "GetCalEvents"
Time cron "0 0/1 * ? * * *"
var String results = executeCommandLine("python /etc/openhab2/scripts/CalSyncHAB/CalSyncHAB.py",1000)
logInfo("GoogleCal", results)
First of all, I would like to apologize if I made a confusion about parameter usage in the script. I’ve used parts of google Python examples to save some time, and, off the top of my head concluded that a script parameter is not being parsed.
Regarding the error message, check the CalSyncHAB folder permissions. If I recall correctly, script writes some temporary file to the folder, so, it should have write permission.
Could you try using “primary” as CalendarId (without quotes, of course) and adding some events to your primary calendar?
Regarding your second question, it’s not possible to have more than one calendar (at least, not with a single script - maybe it would work if you would use multiple scripts in multiple locations - but you would need to have multiple sets of OH items too), but you can change CalendarId in .ini file and make the script synchronize any calendar you have available in your Google account.
I repeated the inital call to the script from outside OH2. CalSyncHAB.py told me that I had to start it with --noauth_local_webserver which means that there must have went something wrong when I entered the verification code some days ago. So, I called the script with the parameter, copied the shown url to my windows machine, retrieved the verification code from google site and pasted it into the script prompt. A few seconds later all my items were filled with my calendar events.
But I’m afraid I have to come up with the next problem. My items have been updated, but only because I started the script from outside openhab. I just saw, that my rule
var String results = executeCommandLine("python /etc/openhab2/scripts/CalSyncHAB/CalSyncHAB.py",10000)
is called, but it does not update my items. The script is still stuck within
var String results = executeCommandLine("/usr/bin/python /home/openhabian/CalSyncHAB/CalSyncHAB.py",120*1000)
logInfo("GoogleCalCron", results)
I made sure that /usr/bin/python --version shows “Python 2.7.9”
I set every single folder and every single file within “/usr/bin/python /home/openhabian/CalSyncHAB” to read, write, exec rights for every user
-> Still the same behavior
Then I deleted all files and also the credentials in google and started from the scratch. The only thing that changed is that now in openhab.log i get:
Failed to start a local webserver listening on either port 8080
or port 8090. Please check your firewall settings and locally
running programs that may be blocking or using those ports.
Falling back to --noauth_local_webserver and continuing with
authorization.
Go to the following link in your browser:
https://accounts.google.com/o/oauth2/auth?scope=https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fcalendar.readonly&redirect_uri=urn%3Aietf%3Awg%3Aoauth%3A2.0%3Aoob&response_type=code&client_id=165856906695-igqva571onj2k0egmmsl5dnj3ato8ks9.apps.googleusercontent.com&access_type=offline
Enter verification code: Traceback (most recent call last):
File "/home/openhabian/CalSyncHAB/CalSyncHAB.py", line 126, in <module>
Main()
File "/home/openhabian/CalSyncHAB/CalSyncHAB.py", line 30, in Main
File "/home/openhabian/CalSyncHAB/CalSyncHAB.py", line 25, in GetCredentials
Credentials = tools.run_flow(AuthenticationFlow, CredentialStore, Flags)
File "/usr/local/lib/python2.7/dist-packages/oauth2client/tools.py", line 239, in run_flow
code = input('Enter verification code: ').strip()
EOFError: EOF when reading a line
This looks like the script can’t send the credentials to google. Why else would it ask “Enter verification code:”? That seems to me is the reason why the scripts never returns to Main() from GetCredentials(). It is waiting for input.
When calling the exact same script from the command line ("/usr/bin/python /home/openhabian/CalSyncHAB/CalSyncHAB.py") there is no prompting for the verification code, everything is alright and my items get updated within seconds.
It looks like the problem is caused by “executeCommandLine”, but I can’t find out why.
