At our home our local council provides two bins - one for waste and the other recycling.
The recycling bin needs to be put out every second week and to help me remember I wanted to create a simple indicator in the UI that would show either just the green waste bin, or both the waste and recycling bin.
There are a bunch of ways to do this, but I wanted to get the whole solution down to the minimum configuration.
First I created a String item:
String BinCollectionWeek “Bin Week [%s]” (Home) // [%s] due to iphone App bug
A Frame in my sitemap:
Frame label="Home Info" { Text item= BinCollectionWeek }
Then a rule to change the state between ‘waste’ or ‘recycling’:
// This rule is designed to show whether it's a recycling bin week or just a waste pickup // It triggers every Monday morning and sets the state of BinCollectionWeek based on // a BinCollectionStartDate - a known recycling week. // The BinCollectionWeek item displays an waste or waste/recycling icon depending on value. rule "Bin Week" when Time cron "0 0 7 ? * MON *" then val DateTime BinCollectionStartDate = new DateTime("2020-08-07T00:00:00") // On this date both recycle and waste was picked up logDebug(LogSubpackage, "Bin Week rule started") // Calculate if it's an even or odd week since BinCollectionStartDate if (Weeks.weeksBetween(BinCollectionStartDate, now).getWeeks() % 2 == 0) BinCollectionWeek.sendCommand("recycling") else BinCollectionWeek.sendCommand("waste") logDebug(LogSubpackage, "Bin Week rule finished") end
Finally two icons:
You’ll also need to copy the ‘bin-waste.png’ file to create a duplicate called ‘bin.png’ as the icon wont appear without it. These files are placed in OPENHAB-conf->icons->classic
Now I have an indicator in my Habpanel app
