I have set up a rule to fire every five minutes. It is running OK for several hours, then the rule engine breaks and no rules are executed any more. Commands still work; e.g. if a press the Button, Radio Starts/stops OK, but the Button which triggers the rule to change the Radio Station send it’s command, but the rule does not fire. I need to remove the rule and Stop/Restart OpenHAB for things to work again. Tried this several times and can drill it down to that rule. Maybe I am missing the obvious, but i can not see anything that might cause the problem. Maybe someone can spot the error?
rule "TempTrend"
Time cron "0 0/5 * * * ?"
//Temeraturtrend alle 5 minuten updaten
logInfo("zuhause.rules","Checke TemeraturTrend......")
//Draussen
if (Terasse_temp.state < Terasse_temp.previousState.state as DecimalType){
sendCommand(TempTrendTerasse,1)//ist gefallen
} else if (Terasse_temp.state == Terasse_temp.previousState.state as DecimalType){
sendCommand(TempTrendTerasse,0)//ist gleich
} else if (Terasse_temp.state > Terasse_temp.previousState.state as DecimalType){
sendCommand(TempTrendTerasse,2)//ist gestiegen
//draussen historisch
sendCommand(TempTrendTerasse10,TempTrendTerasse9.state.toString)
sendCommand(TempTrendTerasse9,TempTrendTerasse8.state.toString)
sendCommand(TempTrendTerasse8,TempTrendTerasse7.state.toString)
sendCommand(TempTrendTerasse7,TempTrendTerasse6.state.toString)
sendCommand(TempTrendTerasse6,TempTrendTerasse5.state.toString)
sendCommand(TempTrendTerasse5,TempTrendTerasse4.state.toString)
sendCommand(TempTrendTerasse4,TempTrendTerasse3.state.toString)
sendCommand(TempTrendTerasse3,TempTrendTerasse2.state.toString)
sendCommand(TempTrendTerasse2,TempTrendTerasse1.state.toString)
sendCommand(TempTrendTerasse1,TempTrendTerasse.state.toString)
//logInfo("zuhause.rules","Checke TemeraturTrend......Draussen fertig. Jetzt WoZi")
//WoZi
if (WoZi_Temp.state < WoZi_Temp.previousState.state as DecimalType){
sendCommand(TempTrendWoZi,1)//gefallen
} else if (WoZi_Temp.state == WoZi_Temp.previousState.state as DecimalType){
sendCommand(TempTrendWoZi,0)//ist gleich
} else if (WoZi_Temp.state > WoZi_Temp.previousState.state as DecimalType){
sendCommand(TempTrendWoZi,2)//ist gestiegen
//histo wozi
sendCommand(TempTrendWoZi10,TempTrendWoZi9.state.toString)
sendCommand(TempTrendWoZi9,TempTrendWoZi8.state.toString)
sendCommand(TempTrendWoZi8,TempTrendWoZi7.state.toString)
sendCommand(TempTrendWoZi7,TempTrendWoZi6.state.toString)
sendCommand(TempTrendWoZi6,TempTrendWoZi5.state.toString)
sendCommand(TempTrendWoZi5,TempTrendWoZi4.state.toString)
sendCommand(TempTrendWoZi4,TempTrendWoZi3.state.toString)
sendCommand(TempTrendWoZi3,TempTrendWoZi2.state.toString)
sendCommand(TempTrendWoZi2,TempTrendWoZi1.state.toString)
sendCommand(TempTrendWoZi1,TempTrendWoZi.state.toString)
logInfo("zuhause.rules","Checke TemeraturTrend......Fertig")
I use the rule to show a temperatur trend:
There are no errors written to the logs. Rule just starts one final time but never reaches the end:
2017-07-12 03:35:00.055 [INFO ] [smarthome.model.script.zuhause.rules] - Checke TemeraturTrend......Fertig
2017-07-12 03:40:00.006 [INFO ] [smarthome.model.script.zuhause.rules] - Checke TemeraturTrend......War: 14.699999999999999289457264239899814128875732421875 Ist: 14.7
2017-07-12 03:40:00.042 [INFO ] [smarthome.model.script.zuhause.rules] - Checke TemeraturTrend......Fertig
2017-07-12 03:45:00.009 [INFO ] [smarthome.model.script.zuhause.rules] - Checke TemeraturTrend......War: 14.699999999999999289457264239899814128875732421875 Ist: 14.7
2017-07-12 03:45:00.040 [INFO ] [smarthome.model.script.zuhause.rules] - Checke TemeraturTrend......Fertig
2017-07-12 03:50:00.007 [INFO ] [smarthome.model.script.zuhause.rules] - Checke TemeraturTrend......War: 14.699999999999999289457264239899814128875732421875 Ist: 14.7
Any ideas?
Many thanks in advance,
Best Regards,
-OLI
