I’m running the latest openHAB 2 beta 5 on a pine64.
I have been experimenting with openHAB and seven Z-Wave devices that I bought to play with. I am now venturing into making rules and got a few extremely trivial rules working. Then I made the following simple rule and it is exhibiting a strange behavior that I don’t understand.
The rule looks at the state of a simple Z-Wave binary power switch and toggles it every 10 seconds. Here’s the rule, which I wrote manually in a text editor (nano):
rule "scare children and old people"
Time cron "0/10 * * * * ?"
logInfo("FILE", "state is: " + zwave_device_controller_node18_switch_binary.state)
if
zwave_device_controller_node18_switch_binary.state==ON
zwave_device_controller_node18_switch_binary.sendCommand(OFF)
// logInfo("FILE", "turned christmas lights off")
else
zwave_device_controller_node18_switch_binary.sendCommand(ON)
// logInfo("FILE", "turned christmas lights on")
When run exactly as shown above, the rule works great and here is its output in openhab.log:
2016-12-27 20:40:45.581 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'myrule.rules'
2016-12-27 20:40:50.304 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: OFF
2016-12-27 20:41:00.015 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: ON
2016-12-27 20:41:10.014 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: OFF
2016-12-27 20:41:20.017 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: ON
2016-12-27 20:41:30.016 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: OFF
Problem is, when I uncomment those two logInfo
lines in the rule, the rule starts misbehaving. The power switch stays off and the log shows:
2016-12-27 20:43:01.428 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'myrule.rules'
2016-12-27 20:43:10.298 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: OFF
2016-12-27 20:43:10.303 [INFO ] [.eclipse.smarthome.model.script.FILE] - turned christmas lights off
2016-12-27 20:43:20.019 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: OFF
2016-12-27 20:43:20.027 [INFO ] [.eclipse.smarthome.model.script.FILE] - turned christmas lights off
2016-12-27 20:43:30.016 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: OFF
2016-12-27 20:43:30.031 [INFO ] [.eclipse.smarthome.model.script.FILE] - turned christmas lights off
2016-12-27 20:43:40.017 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: OFF
2016-12-27 20:43:40.026 [INFO ] [.eclipse.smarthome.model.script.FILE] - turned christmas lights off
2016-12-27 20:43:50.015 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: OFF
2016-12-27 20:43:50.027 [INFO ] [.eclipse.smarthome.model.script.FILE] - turned christmas lights off
2016-12-27 20:44:00.044 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: ON
2016-12-27 20:44:00.050 [INFO ] [.eclipse.smarthome.model.script.FILE] - turned christmas lights off
2016-12-27 20:44:10.014 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: OFF
2016-12-27 20:44:10.022 [INFO ] [.eclipse.smarthome.model.script.FILE] - turned christmas lights off
2016-12-27 20:44:20.015 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: OFF
2016-12-27 20:44:20.022 [INFO ] [.eclipse.smarthome.model.script.FILE] - turned christmas lights off
2016-12-27 20:44:30.014 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: OFF
2016-12-27 20:44:30.023 [INFO ] [.eclipse.smarthome.model.script.FILE] - turned christmas lights off
2016-12-27 20:44:40.014 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: OFF
2016-12-27 20:44:40.021 [INFO ] [.eclipse.smarthome.model.script.FILE] - turned christmas lights off
2016-12-27 20:44:50.014 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: OFF
2016-12-27 20:44:50.030 [INFO ] [.eclipse.smarthome.model.script.FILE] - turned christmas lights off
2016-12-27 20:45:00.048 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: ON
2016-12-27 20:45:00.054 [INFO ] [.eclipse.smarthome.model.script.FILE] - turned christmas lights off
2016-12-27 20:45:10.019 [INFO ] [.eclipse.smarthome.model.script.FILE] - state is: OFF
2016-12-27 20:45:10.027 [INFO ] [.eclipse.smarthome.model.script.FILE] - turned christmas lights off
Note that it occasionally says that the “state is: ON”. This is a lie. The switch is definitely off as confirmed physically. Even the control switch in the Paper UI control section stays in the off position, so it doesn’t even appear that the underlying system believes that the state is ON.
Also note that even though the rule thinks the state is off, it still tries to turn the switch off, which seems virtually impossible given the rule code.
The most curious thing about this is that simple logging actions seems to be modifying the behavior of the rule!
I have a feeling I’m missing something simple. Can anyone help?
Here’s some theories:
- The
state
attribute of the item has side effects I would not have anticipated. - I’m posing my conditional wrongly.
- I have a syntax error.
- There’s a bug related to the
logInfo
action.
