Hi All
I created an offset event which appears to work, 20mins before Sunset.
Its meant to turn on the motion sensor and on the lights, but nothing is occuring nor do I see any errors in the log.
the if statement checks a proxy item, so I can disable the rule if need be but it appears to not trigger any events. Even if this proxy is OFF, it should still enable the Motion sensor.
rule "Turn on harbour side lights at 20mins prior to sunset"
Channel 'astro:sun:sunset20mins_before' triggered START
MasterBed_Motion_Armed.sendCommand(ON)
Sunset.postUpdate(OFF)
if(HarbourLights_BeforeSunset.state == ON){
RearGarden_Sw1.sendCommand(ON)
Entrance_Sw1.sendCommand(ON)
logInfo("Lights","Turn on harbour side lights 20mins prior to sunset")
2019-12-11 19:37:00.003 [vent.ChannelTriggeredEvent] - astro:sun:sunset20mins_before:set#event triggered START
2019-12-11 19:40:00.003 [vent.ChannelTriggeredEvent] - astro:sun:sunset20mins_before:set#event triggered END
I cannot see what Im doing wrong, any suggestions?
Thank you!
