Simple rule given warning and ignoring
Can anyone tell me why this rule is given me a warning and ignoring:
log file:
2018-08-05 18:13:27.137 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'motionering.rules' has errors, therefore ignoring it: [9,1]: missing EOF at 'when'
.rule file
rule "Ventil motionering startet"
	Item aktivitetVentilMotion changed from 0 to 1       // motion begin
	aktivitetVentilMotionStamp.postUpdate(new DateTimeType())   // defaults to now
	Item amandaVentilMotion changed from 0 to 1       // motion begin
	amandaVentilMotionStamp.postUpdate(new DateTimeType())   // defaults to now
	Item bryggersVentilMotion changed from 0 to 1       // motion begin
	bryggersVentilMotionStamp.postUpdate(new DateTimeType())   //defaults to now
	Item casperVentilMotion changed from 0 to 1       // motion begin
	casperVentilMotionStamp.postUpdate(new DateTimeType())   //defaults to now
	Item koekkenVentilMotion changed from 0 to 1       // motion begin
	koekkenVentilMotionStamp.postUpdate(new DateTimeType())   //defaults to now
	Item kontorVentilMotion changed from 0 to 1       // motion begin
	kontorVentilMotionStamp.postUpdate(new DateTimeType())   //defaults to now
	Item lilleBadVentilMotion changed from 0 to 1       // motion begin
	lilleBadVentilMotionStamp.postUpdate(new DateTimeType())   //defaults to now
	Item marcVentilMotion changed from 0 to 1       // motion begin
	marcVentilMotionStamp.postUpdate(new DateTimeType())   //defaults to now
	Item soveBadVentilMotion changed from 0 to 1       // motion begin
	soveBadVentilMotionStamp.postUpdate(new DateTimeType())   //defaults to now
	Item spisestueVentilMotion changed from 0 to 1       // motion begin
	spisestueVentilMotionStamp.postUpdate(new DateTimeType())   //defaults to now
	Item stortBadVentilMotion changed from 0 to 1       // motion begin
	stortBadVentilMotionStamp.postUpdate(new DateTimeType())   //defaults to now
	Item stueBadVentilMotion changed from 0 to 1       // motion begin
	stueBadVentilMotionStamp.postUpdate(new DateTimeType())   //defaults to now
You has defined only one rule with pattern
rule "my rule"
    Item myItem changed
    do some thing
all your other “rule” are missing the rule an therefore openHAB finds an error
It is simular to this rule I´ve got, which is working just fine. So I don´t really understand why the above fails.
rule "Multisensor6 PIR Last Updated"
	Item ZWaveNode5ZW100MultiSensor6_MotionAlarm changed from OFF to ON       // motion begin
	ZWaveNode5ZW100MultiSensor6_MotionAlarm_stamp.postUpdate(new DateTimeType())   //defaults to now
    logInfo("PIRupdate.rules", "Multisensor 6 opdatering.")
       // ..... do other stuff
This rule is complete, but your rule set isn’t complete. i just copied from your rule
<<<----- Here is something missing ----->
rule "This is the next rule"
Compare this to your rule/ rules
So what you say is, that there has to be a rule “xxxx xxx xxx” after each end?
You should see it the other was round. each rule start with a rule and ends with end. You have, if i count right, 12 rules, but only one times the keyword rule.
A good practice on such errors (know knowing why there is an error) is to put most of the code into comments and adds parats by parts until the error comes up.
I hear you, and I´ll give it a try. But this is my rule file for setting a datetime stamp whenever a motion PIR is changed. It´s working just fine, and does not threw an warning. Please notice the exact same process:
//Soveværelse
rule "Soveværelse PIR Last Updated"
	Item sove_pir changed from OFF to ON       // motion begin
	sove_pir_stamp.postUpdate(new DateTimeType())   //defaults to now
//Stuen
rule "Stue PIR Last Updated"
	Item stue_pir changed from OFF to ON       // motion begin
	stue_pir_stamp.postUpdate(new DateTimeType())   //defaults to now
//Spisestuen
rule "Spisestue PIR Last Updated"
	Item spise_pir changed from OFF to ON       // motion begin
	spise_pir_stamp.postUpdate(new DateTimeType())   //defaults to now
//Aktivitetsrum
rule "Aktivitestrum PIR Last Updated"
	Item aktivitet_pir changed from OFF to ON       // motion begin
	aktivitet_pir_stamp.postUpdate(new DateTimeType())   //defaults to now
//Caspers
	Item casper_pir changed from OFF to ON       // motion begin
	casper_pir_stamp.postUpdate(new DateTimeType())   //defaults to now
//Amandas
	Item amanda_pir changed from OFF to ON       // motion begin
	amanda_pir_stamp.postUpdate(new DateTimeType())   //defaults to now
//Marcs
	Item marc_pir changed from OFF to ON       // motion begin
	marc_pir_stamp.postUpdate(new DateTimeType())   //defaults to now
//Garage
rule "Garage PIR Last Updated"
	Item garage_pir changed from OFF to ON       // motion begin
	garage_pir_stamp.postUpdate(new DateTimeType())   //defaults to now
//Udvendig indgangsparti
rule "Udv indgang PIR Last Updated"
	Item pir_indgang changed from OFF to ON       // motion begin
	pir_indgang_stamp.postUpdate(new DateTimeType())   //defaults to now
rule "Vision PIR alarm"
	Item Node10_AlarmBurglar changed from OFF to ON       // motion begin
	Node10_AlarmBurglar_stamp.postUpdate(new DateTimeType())   //defaults to now
rule "Neo Coolcam PIR alarm"
	Item Node13_AlarmBurglar changed from OFF to ON       // motion begin
    logInfo("item", "ZwaveNode13 sets update.")
	Node13_AlarmBurglar_stamp.postUpdate(new DateTimeType())   //defaults to now
rule "Vision Garageport sensor"
	Item GarageDoorTiltSensor_BinarySensor changed from CLOSED to OPEN       // motion begin
	GarageDoorTiltSensor_BinarySensor_stamp.postUpdate(new DateTimeType())   //defaults to now
I would suspect this gave an warning and ignoring as well. This is actually my reference rule for the above, which is not working.
Just tried. And you were right. It no longer throws an warning…
ARRGH… Damit, I see it now… The reference rules DO contain rule “” for each rule…
Damit I´m tired :frowning: Sorry for taking your time.
Hello @Kim_Andersen
I see that you have solved the problem you had.
Now, you end up with 12 rules.
These 12 rules can be put into ONE!!! Yes
Put all the items triggering the rules into a Group:
Group gVentilMotion
Rule:
rule "Ventil mitionering startet"
    Member of gVentilMotion changed from 0 to 1
    val String itemName = triggeringItem.name.toString
    postUpdate(itemName + "Stamp", now.toString)
That’s it…
From 72 lines of code to 7
:slight_smile: no problem. take a nap and start coding again
Thanks alot Vincent.
I knew there probably were some way to make this more simple. I just didn´t have the knowledge to do it. Now I do :slight_smile:
I will give it a try later. It´s not fun doing alot of unnessesary copy/paste :slight_smile:
trigger should be
:wink:
@vzorglub
And it works like a dream, even with Udo´s change, (which I had spotted btw :slight_smile: )
