Simple rule help
Gday,
I am having a go at putting some rules in place for a simple home alarm that will have switch type inputs and a switch output for a siren along with a bunch of notifications.
I have set up all the items as switches and have this in the sitemap, to switch off, on(window, door & PIR) and internal (just window & door reed switches) modes.
Switch item=Alarmmode label="Alarm mode selection" mappings=[1=OFF, 2=ON, 3=Internal] icon="settings"
The first rule works well and changes state of the 3 switches. The second rule “Alarm triggers” does not seem to work.
Could someone point me in the right direction?
//Alarm Rules
rule "Alarm Mode"
	Item Alarmmode received command
	if(receivedCommand==1) {
		sendCommand(AlarmOFF, ON)
		sendCommand(AlarmON, OFF)
		sendCommand(Alarminternal, OFF)
	else
		if(receivedCommand==2) {
		sendCommand(AlarmOFF, OFF)
		sendCommand(AlarmON, ON)
	else
		if(receivedCommand==3) {
		sendCommand(Alarminternal, ON)
rule "Alarm triggers"
	Item AlarmON received command ON
	if(Windows==ON) {
		sendCommand(Alarmtriggered, ON)
	if(Doors==ON) {
	if(PIR1==ON) {
Kind Regards,
George
Hi George,
I assume that Windows, Doors and PIR are items. If so, the right syntax is:
if (Windows.state==ON) { // Do something }
You missed the .state
Thomas
Thomas,
Thanks for that, much appreciated. I am still quite new to rules.
Do you know if there is summary sheet or similar on the syntax for the most common type of things in rules?
Cheers,
George
George,
i don’t think so, just use the Wiki with the examples and ask if you do not find a solution.
Thomas
The closest you will get to a summary is the Rules wiki page. For more in depth stuff you can read the Xtend language docs (linked to on the Rules page). But as @Dibbler42 says, examples will be a large part of your learning.
No worries, thanks for that.
Cheers,
George
hi george , did you ever finish your alarm ?
if so , i think this can be a very intresting project as i have not seen many rules about that topic yet.
would you be so kind to a post about your working configuration ?
kindest regards
