I am working with OpenHAB for years now, but every once in a while, I loose an hair on the rule engine. Right now, this is such a moment and I would be thankful if somebody can have a quick look, please?
Switch Basement_Switch_Door_Switch "Steckdose Eingang Ein / Ausschalten [%s]" <power> (G_Basement_Switch_Door)
Switch Basement_CeilingLightLeft_Switch "Linkes Kellernlicht" <light> (G_Basement_LightsSwitches, G_Basement_CeilingLightLeft) [ "Lighting" ]
Switch Basement_CeilingLightRight_Switch "Rechtes Kellernlicht" <light> (G_Basement_LightsSwitches, G_Basement_CeilingLightLeft) [ "Lighting" ] {channel="zwave:device:ef00bd02:node10:switch_binary1"}
rule "Light switches in basement"
Item Basement_Switch_Door_Switch changed
Basement_CeilingLightLeft_Switch.sendCommand(Basement_Switch_Door_Switch.state)
Basement_CeilingLightRight_Switch.sendCommand(Basement_Switch_Door_Switch.state)
2020-04-14 20:25:16.369 [ome.event.ItemCommandEvent] - Item 'Basement_Switch_Door_Switch' received command OFF
2020-04-14 20:25:16.370 [vent.ItemStateChangedEvent] - Basement_Switch_Door_Switch changed from ON to OFF
2020-04-14 20:25:16.371 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Light switches in basement': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.sendCommand(org.eclipse.smarthome.core.items.Item,java.lang.Number) on instance: null
2020-04-14 20:25:17.557 [ome.event.ItemCommandEvent] - Item 'Basement_Switch_Door_Switch' received command ON
2020-04-14 20:25:17.560 [vent.ItemStateChangedEvent] - Basement_Switch_Door_Switch changed from OFF to ON
2020-04-14 20:25:17.560 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Light switches in basement': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.sendCommand(org.eclipse.smarthome.core.items.Item,java.lang.Number) on instance: null
Thanks a lot!
PhiL
