Simple Settemp Listwidget
Bildschirmfoto 2022-01-25 um 13.50.11
Simple but useful listitem widget for temperature setting via stepper and displaying the current value.
The Standard Stepper listitem is out of the box not capable to handle another value. With the widget it is also easy to use global min/max values for the stepper.
Default Values can be set if no properties are given. So it’s quite usable without any customizing.
icon: “=props.seticon ? props.seticon : ‘f7:house_alt_fill’”
Influde it e.g. via items file:
 Number        Temp_Flur      "Temp Flur [%.1f °C]"    <temperature> (KNXDevice) ["Temperature",   "Measurement"]   { channel="knx:device:bridge:generic:KNXTemp_Flur" }
 Number        Set_Temp_Flur      "Temp Flur [%.1f °C]"    <temperature> (Flur) ["Temperature",   "Setpoint"]   { channel="knx:device:bridge:generic:KNXTemp_Flur_Soll", listWidget="widget:Temp_list_widget" [title="Set my temp Flur", isttemp="Temp_Flur", icon="oh:temperature]}
Screenshots
none
Changelog
Version 0.1
  • initial release
Resources
uid: Temp_list_widget
tags:
  - list
  - temperature
props:
  parameters:
    - description: The label for the widget
      label: Title
      required: false
      type: TEXT
    - context: item
      description: The temperature item
      label: Item
      required: false
      type: TEXT
    - context: item
      description: Current Temp
      label: Current temperature
      required: false
      type: TEXT
    - description: Icon
      label: List Icon
      required: false
      type: TEXT
    - description: Min Value
      label: Min
      required: false
      type: TEXT
      label: Max
      required: false
      type: TEXT
      label: step
      required: false
      type: TEXT
  parameterGroups: []
timestamp: Jan 25, 2022, 1:34:25 PM
component: oh-stepper-item
  icon: "=props.seticon ? props.seticon : 'f7:house_alt_fill'"
  title: "=props.title ? props.title : props.item"
  item: =props.item
  subtitle: =items[props.isttemp].displayState
  round: =1
  min: "=props.minset ? props.minset : 7"
  max: "=props.maxset ? props.maxset : 25"
  step: "=props.stepset ? props.stepset : 0.5"
I have the problem that I get the actual temperature sometimes displayed sometimes not. The code always looks the same. What can be the reason for this?
blocks:
  - component: oh-block
    config: {}
    slots:
      default:
        - component: oh-grid-row
          config: {}
          slots:
            default:
              - component: oh-grid-col
                config: {}
                slots:
                  default:
                    - component: oh-list-card
                        accordionList: false
                        mediaList: true
                      slots:
                        default:
                          - component: oh-stepper-item
                              fill: false
                              icon: oh:heating
                              item: TadoControl_AwayTemperature
                              max: 25
                              min: 15
                              round: true
                              step: 0.5
                              title: Tado Away Temp.
                          - component: widget:Temp_list_widget
                              isttemp: KucheHeizkorperthermostat_Currenttemperature
                              item: KucheHeizkorperthermostat_Setpointheat
                              maxset: "25"
                              minset: "15"
                              seticon: oh:Temperature
                              stepset: "0.5"
                              title: Küche
                              isttemp: SchlafzimmerHeizkorperthermostat_Currenttemperature
                              item: SchlafzimmerHeizkorperthermostat_Setpointheat
                              maxset: "25"
                              minset: "15"
                              stepset: "0.5"
                              title: Schlafzimmer
                              isttemp: WohnzimmerHeizkorperthermostat_Currenttemperature
                              item: WohnzimmerHeizkorperthermostat_Setpointheat
                              maxset: "25"
                              minset: "15"
                              stepset: "0.5"
                              title: Wohnzimmer
I have also extended the widget analyzer function of the actual value.
  action: analyzer
  actionAnalyzerCoordSystem: time
  actionAnalyzerItems: =[props.isttemp]
  item: =props.item
