Hi I have a problem with a simple rule for controling a 3 way valve based on the sensor temp.
The script is found on internet but when adapted it throws.
2016-04-27 00:42:34.721 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'heating water thermostat': Cannot cast org.openhab.core.library.types.DecimalType to void
This must be something with the variable declaration, as it will happen even with just firs 3 lines.
Here is the rule
rule "heating water thermostat"
Item B_Temperature_Water_Setpoint changed or
Item B_Temperature_tgS_heating_water changed
var Number setpoint = B_Temperature_Water_Setpoint.state as DecimalType
var Number cur_temp = B_Temperature_tgS_heating_water.state as DecimalType
val hysteresis = 0.5
if (cur_temp <= (setpoint - hysteresis)) {
if (boiler_outb0.state == OFF) {
sendCommand(boiler_outb1, OFF)
sendCommand(boiler_outb0, ON)
else {
sendCommand(boiler_outb0, OFF)
if (cur_temp >= (setpoint + hysteresis)) {
if (boiler_outb1.state == OFF) {
sendCommand(boiler_outb1, ON)
else {
Since you can use a DecimalType as a Number, why not define them as:
var DecimalType setpoint = B_Temperature_Water_Setpoint.state as DecimalType
var DecimalType setpoint = B_Temperature_tgS_heating_water.state as DecimalType
I assume both Items are Number Items and not some other Item type.
that did not help and and I still get the exception.
And yes in the items file both are declared as Numbers
Number B_Temperature_tgS_heating_water "Temp_tgS Floor Heating Water [%.1f C]" <temperature> (TempChart_heating_water,TempChart1,gBasement) {tinkerforge="uid=tgS"}
Number B_Temperature_Water_Setpoint "Heating Water Setpoint [%.1f °C]" <degreesc> (HeatingSetpoint)
Ok I solved the problem, but I still do not understand why the following code work while the previous one does not
if ((cur_temp).floatValue < ((setpoint).floatValue - hysteresis)) {
else {
