Simple Timer switch rule help
Hi There,
I’m trying to get a really simple rule working which switches my tellstick nexa switch on and off everyday, but I don’t seem to be getting something right. My rule is below
rule “Switch on”
Time cron “0 55 7 1/1 * ? *"
sendCommand(bedsw,ON)
rule “Switch off”
Time cron “0 0 8 ? * MON-FRI *”
sendCommand(bedsw,OFF)
I have been watching the logs and I see the rule refreshes, but there is nothing being triggered in the logs :frowning:
PLEASE HELP!
First add some logging messages to the THEN clauses of your rules to see if they are even being triggered. (ie to see if your cron clauses are correctly formed).
If the rules are being triggered correctly via cron, then look to your item definition. Can you manipulate “bedsw” as defined thru a UI widget ?
Hi Bob,
Thanks for the reply, I have the switches already working in the openhab web UI just fine, so I’m slightly confused as to why the rule isn’t working? I have running openhab on a rasperberrypi 2 with the latest version of Rasbian jesse.
Are you able to tell me how to add logging messages? or is there a good guide somewhere? Thanks
In your case something like
rule "Switch on"
    Time cron "0 55 7 1/1 * ? *"
    logInfo("My switch rule", "cron has been triggered")
should help
good luck
Just to clarify @sam 's comment, the first phrase in the LogInfo command must match the name of a logger defined in logback.xml…a literal “My switch rule” may lead to (cough) “perplexing behavior”. Personally I have 8-10 loggers defined which route messages to different logfiles based on this behavior. NB you need both <appender…> and <logger…> definitions…
            %d{HH:mm:ss.SSS} %-5level %logger{30}[:%line] - %msg%n%ex{0}
        ${openhab.logdir:-logs}/openhab.log
            %d{HH:mm:ss.SSS} %-5level %logger{30}[:%line]- %msg%n%ex{5}
        ${openhab.logdir:-logs}/events.log
            ${openhab.logdir:-logs}/events-%d{yyyy-ww}.log.zip
            30
            %d{yyyy-MM-dd HH:mm:ss} - %msg%n
        ${openhab.logdir:-logs}/rulelog.log
            ${openhab.logdir:-logs}/rulelog-%d{yyyy-ww}.log.zip
            30
            %d{yyyy-MM-dd HH:mm:ss} - %-5level %logger{30}[:%line]- %msg%n
        ${openhab.logdir:-logs}/startup.log
            30
        ${openhab.logdir:-logs}/2f.log
            30
        ${openhab.logdir:-logs}/shutdown.log
            30
        ${openhab.logdir:-logs}/kitchen.log
            30
        ${openhab.logdir:-logs}/stairwell.log
            30
        ${openhab.logdir:-logs}/hvac.log
            30
        ${openhab.logdir:-logs}/living.log
            30
        ${openhab.logdir:-logs}/zwave.log
            ${openhab.logdir:-logs}/zwave-%d{yyyy-ww}.log.zip
            30
            %d{yyyy-MM-dd HH:mm:ss.SSS} %-5level %logger{30}[:%line]- %msg%n%ex{5}
        ${openhab.logdir:-logs}/mqtt.log
            ${openhab.logdir:-logs}/mqtt-%d{yyyy-ww}.log.zip
            30
Thanks @bob_dickenson
:smile:
Can you expand a little more on what you mean?
Perhaps with an example of how you then write to your 8-10 logs?
I have successfully been using lines like:
logInfo("Fon_IFTTT_Switch", "received command")
logInfo("Lux_Sensor", "received changed")
They all write to the same openhab.log file, but that is fine. I use iTerm to search and filter a tail when I am looking for something.
I thought perhaps you were referring to the spaces in "My Switch Rule" as I typically use an item or variable name in the first bit.
But I tested exact example given and it seemed to output what it was supposed to do correctly.
logWarn("My switch rule", "cron has been triggered")
2016-01-22 21:33:00.505 [WARN ] [.o.model.script.My switch rule] - cron has been triggered
Granted my knowledge of logging is cobbled together from scripts written by others. So I am always keen to learn where I am going wrong and why.
Many thanks
you can direct message to the appropriate log via the first argument to your logInfo (or logDebug etc) statement. E.g. logInfo(“KITCHEN”,“foobar”) will write “foobar” to the logfile described by appender and logger elements for “KITCHEN”.
            30
Thanks… and I think I can assume that anything that doesn’t match “KITCHEN” would be sent to default?
yes – or to anything it DID match. Personally I have 8-10 different loggers for various rooms/subsystems in my house.
