I have a setup with heating regulators. Eurotronic Zwave Spirit.
On OH2x I have defined a virtual switch (Switch HVAC_OnOff “AZ_Heat_OnOff”) defined in an .item File.
With that Switch I activate or deactivate alle heating items in all rooms.
No I’m going to port my setup to OH 3.
I did this on a second system and will setup all from a fresh state.
So I just played a little bit.
I created a simple switch item on the UI.
When I saved it, i saw the UI Item in the browser an can toogle it.
But when I look in the logs I saw that only the ON State is logged. The off-State not.
I used also a rule with a script to log the states.
This also works only for changing to on.
