I have a startup rule:
rule Startup
System started
VoiceCommand.postUpdate("----")
rule Startup
System started
Thanks, got it working. When items are exposed to myopenhab.org they will only show up once there has been an update to the item. That’s why a forced value was needed. I believe there should be no reason to force a value anymore once the items is fully exposed.
Like you said, this creates a problem with items that contains numbers (dimmers, thermostat setpoints, volume). I’m not sure which way is better due to that.
I can’t admit to understand, but have you looked at the git page here:
https://github.com/openhab/openhab/wiki/Controlling-openHAB-with-your-voice
The rules seem to have a way to parse for numbers, be it decimals or percent. I’m more of a copy and paste coder but maybe there is a way to use these in conjunction so that Google Assistant pushes to text phrase but the rule parses out the number.
An update…
I tried switching to HueEmulation with Google Home, but IFTTT is as responsive and works better in general. I also have more control of what happens with rules vs names of devices. I was surprised since there are a couple of additional hops with IFTTT.
FYI, this also works with Google Assistant on android phones.
@ranielsen or anyone, would you mind sharing your rule that you use for processing? I have found a few examples but they all error out on me.
I have the data getting from my Google Home to IFTT and to MyOpenHAB and to my local install but it dies on the rule
@p0lar, here’s part of my rule:
rule "Voice control"
Item VoiceCommand received command
// https://github.com/openhab/openhab/wiki/Controlling-openHAB-with-your-voice
var String command = VoiceCommand.state.toString.toLowerCase
logInfo("voice control","VoiceCommand received " + command)
var String cmd = null
if (command.contains("on")) {
cmd = "ON"
} else if (command.contains("off")) {
cmd = "OFF"
} else if (command.contains("open")) {
cmd = "OPEN"
} else if (command.contains("close") || (command.contains("shut")) {
cmd = "CLOSE"
if (cmd == "ON" || cmd == "OFF") {
// main floor
if (command.contains("living room") || command.contains("main floor")) {
sendCommand(mLivingLights, cmd)
sendCommand(mLivingLamp, cmd)
if (command.contains("dining room") || command.contains("main floor")) {
sendCommand(mDiningLights, cmd)
} else if (cmd == "OPEN" || cmd == "CLOSE") {
// garage
if (command.contains("garage door")) {
if (cmd == "OPEN") {
sendCommand(garageDoorOpen, ON)
} else if (cmd == "CLOSE") {
sendCommand(garageDoorClose, ON)
Cool Thanks. that works better
now to write one that does not need an IF for each word
Glad it helps, Please share the one that doesn’t use an if for each word!
I have just configured IFTTT and openHAB so that the VoiceCommand item gets my “commands”. It seems to be working, unfortunately, it also seems like everything I tell my Google Home mini is sent to openHAB.
The trigger I created (“What do you want to say?”) is “bitte $”. So I thought only those commands that start with “bitte” will be sent to openHAB, but that doesn’t seem to be the case.
What do I have to do to make it work that way? I can’t really use the Home mini for anything else now.
Ok, nevermind, seems to be “bitte” is just ignored(?). I changed it to “test” and it works.
I guess I’ll have to come up with some phrase that makes it somewhat intuitive to use. Or I’ll have to add all kinds of applets with different trigger phrases.
One more thing: It seems to be working rather well, exposing the VoiceCommand item in the openHAB cloud. What bothers me though is the need to use a trigger phrase (which in my case is still “test”: “Hey Google, test, turn on the kitchen light”). I can’t think of a intuitive phrase to use.
So I was thinking if it would be possible to “route” all commands that I speak into Google Home to my VoiceCommand item in openHAB first, see if there is a command that I wanto openHAB to execute, and then send everything else “back” to the Google Home. It would require the Google Home / Assistant to have some kind of functionality to receive commands via text / interface, which I havent really found so far. I found this: https://github.com/noelportugal/google-home-notifier, but it seems like this is only usable for sending text to the Home which it then “speaks” via the built in speaker.
Does anyone know if that would be possible?
I’m having no problems with “Hey Google, turn on the kitchen lights”
I don’t really want to be “restricted” that way. I would like to be able to use commands in whichever way I want (“Hey Google, kitchen lights off”, “Hey Google, turn kitchen lights off”, “Hey Google, lights in kitchen off” etc.). That works with the Android openHAB app already, and I don’t want to have to use a different syntax with the Google Home. It seems like there is (currently) no way to control the Home via some network interface.
Here’s my rule which I can turn on/off lights, even chain multiple lights together
Text ingredient: Turn $
Assistant response: OK, I’m turning $
Send to VoiceCommand: turn {{TextField}}
The only restriction is I have to say the word “turn”.
Yea, that’s what I mean. I don’t want to have to say “turn” every single time. In the english language there might not be so may ways to say “turn off the lights”, but in the german language there are quite a few (“mach das licht in der küche an”, “schalte das licht in der küche an”, “licht in der küche an”, “küchenlicht anschalten” and many more). In addition to that, I dim my lights, so I will have to add all kinds of applets or trigger phrases.
Also, there are things that Google Home/Assistent itself could be told to turn on (e.g. “turn the music on”), which would not work with your applet/rule, as the command is routed to your openHAB. You would then have to use a different command (“play music” instead of “turn on music”).
I want to have kind of a natural language processing. I don’t want to (and I don’t want to have my wife have to) learn an exact phrase that she has to use to turn on a light. I want it to be as intuitive as possible. That would work if I had the chance to send everything to openHAB first, my rule would then see if the command is anything that should be done via openHAB (like this https://github.com/openhab/openhab1-addons/wiki/Controlling-openHAB-with-your-voice), and if the command is not for openHAB itself, it could then send it “back” to the Home/Assistant.
where does this file go im having trouble exposing items
Unfortunately there’s no way to do what you’re looking to do. There is no way to capture what you hear and send it back if it’s not what you want. As for processing the language, that’s what makes the Google assistant what it is. Google has been working on that AI engine for years and it requires special programming languages for natural language processing, so I don’t think trying to do it in OH is going to be effective. You would have to choose every key word that would possible be uttered and parse for it and try to figure out the context of what someone is saying, which is what Google’s machine learning algorithms have been developed for over the past decade. It’s actually a lot harder than people think it is.
As of right now if you want the full benefit of natural language processing you can either wait for the OH skill to come out on the Google assistant or you can write multiple rules in IFTTT to try to catch all scenarios. There is always one other option and that would be to write your own Google assistant action.
Thanks for your reply.
I have been using a changed version of the “natural language processing script” which I posted above (https://github.com/openhab/openhab1-addons/wiki/Controlling-openHAB-with-your-voice) for a while now, and it’s working just fine for my needs. I don’t really need it to be as good as Googles natural language processing.
I do not have to keep using an exact phrase like “Turn kitchen lights off”, as long as the sentence contains everything the script needs it works fine (“kitchen lights off”, “lights in kitchen off”, “roller shutter living room down”, “close shutters in living room” etc).
I’m waiting for the Google Home openHAB integration at the moment. Looking forward to trying that.
Hi all,
just had a quick read of this long discussion and I just have one question before I continue. For all this to work, are you using the openhab applet in IFTTT? and if so, does that require using myopenhab,org? Or are you using IFTTT directly back to your openhab system at home?
Thanks,
Will.
what do you mean please by “force value”?
