I recycled some controls I made for my rollershutter widget and created a simple widget to control the sunblind on my terrace:
uid: markise_v1
tags: []
props:
parameters:
- description: Title of the card (empty for none)
label: Title
required: false
type: TEXT
- description: The card footer (empty for none)
label: Footer
required: false
type: TEXT
- description: The label on top of the controls (empty for none)
label: Label
required: false
type: TEXT
- context: item
description: Sunblind control (receives Up, Down, My commands as String)
label: Sunblind control
required: true
type: TEXT
parameterGroups: []
timestamp: Feb 24, 2021, 1:57:03 PM
component: f7-card
title: =props.title
slots:
default:
- component: f7-card-content
slots:
default:
- component: f7-row
class:
- display-flex
- justify-content-center
- align-items-flex-start
style:
height: 25px
slots:
default:
- component: f7-block-header
slots:
default:
- component: Label
text: =props.label
- component: f7-row
class:
- display-flex
- justify-content-space-evenly
- align-items-center
style:
width: 100%
height: 150px
slots:
default:
- component: f7-col
class:
- display-flex
- flex-direction-column
style:
height: calc(100% - 20px)
slots:
default:
- component: oh-link
actionItem: =props.control
actionCommand: Up
action: command
colorTheme: gray
iconF7: arrowtriangle_up
iconSize: 20
style:
background-color: rgba(246, 158, 81, 0.2)
border-radius: 15px 15px 0px 0px
padding: 10px
width: 40px
actionCommand: My
action: command
text: my
style:
padding: 10px
width: 40px
actionCommand: Down
action: command
colorTheme: gray
iconF7: arrowtriangle_down
iconSize: 20
style:
border-radius: 0px 0px 15px 15px
padding: 10px
width: 40px
- component: f7-card-footer
slots:
default:
- component: Label
text: =props.footer
Configuration is very straightforward since you only need an item that receives Up / Down / My command strings. The rest is up to you to handle (e.g. in a rule). Since I cannot get the actual state back from my sunblind I simply set the state to the last pressed button which may not be correct in all cases e.g. when the “my” button is pressed when the sunblinds are one of the end positions or someone uses the actual remote to move the blinds.
I ended up with this simple design after I tried some more weird prototypes like this:
Even though I decided not use it it might be interesting for someone elses project:
uid: markise_v2
tags: []
props:
parameters:
label: Title
required: false
type: TEXT
label: Footer
required: false
type: TEXT
label: Label
required: false
type: TEXT
label: State
required: false
type: TEXT
- context: item
required: true
type: TEXT
parameterGroups: []
timestamp: Feb 23, 2021, 10:14:07 PM
component: f7-card
title: =props.title
slots:
default:
slots:
default:
- component: f7-row
class:
- display-flex
style:
height: 25px
slots:
default:
slots:
default:
- component: Label
text: =props.label
- component: f7-row
class:
- display-flex
style:
width: 100%
height: 100px
slots:
default:
- component: f7-col
class:
- display-flex
- justifiy-content-center
style:
height: 150px
slots:
default:
class:
- display-flex
- align-items-flex-end
style:
height: 100%
width: 200px
border: solid 1pt lightgray
border-bottom: none
transition: transform 10s
transform: '= props.state == "DRIN" ? "translate(0, -125px) scale(0.8, 0.05) perspective(250px) rotateX(60deg)": "translate(0, -85px) scale(1, 1) perspective(250px) rotateX(60deg)"'
transform-origin: bottom center
slots:
default:
- component: oh-repeater
for: i
rangeStart: 0
rangeStop: 11
rangeStep: 1
sourceType: range
fragment: true
slots:
default:
class:
- no-padding
- flex-shrink-0
style:
height: 100%
width: 20px
background-color: '=loop.i % 2 == 0 ? "rgba(246, 158, 81, 0.25)" : "rgba(0,0,0,0.01)"'
border: solid 1pt rgba(0, 0, 0, 0.1)
class:
- display-flex
style:
width: 300px
transform: '= props.state == "DRIN" ? "translate(0, -128px) scale(0.8, 0.8)": "translate(0, -85px) scale(1, 1)"'
slots:
default:
for: i
rangeStart: 0
rangeStop: 11
rangeStep: 1
sourceType: range
fragment: true
slots:
default:
class:
- no-padding
- flex-shrink-0
style:
margin-top: 0px
height: 15px
width: 20px
border-radius: 0 0 10px 10px
background-color: '=loop.i % 2 == 0 ? "rgba(246, 158, 81, 0.2)" : "white"'
border-top: none
- component: f7-row
class:
- display-flex
style:
width: 100%
height: 50px
slots:
default:
actionCommand: Up
action: command
colorTheme: gray
iconSize: 20
style:
border-radius: 15px 0px 0px 15px
padding: 10px
height: 40px
actionCommand: My
action: command
text: MY
style:
padding: 10px
height: 40px
actionCommand: Down
action: command
colorTheme: gray
iconSize: 20
style:
border-radius: 0px 15px 15px 0px
padding: 10px
height: 40px
slots:
default:
- component: Label
text: =props.footer
