Simple zoneminder motion rule with timer
Im trying to setup a motion dect (via Zoneminder) to trigger a light. I see messages in the log file where the motion is toggling ON/ OFF, however, my newbie script is not turning on a light. Any help appreciated! THX.
Rules:
var Integer counter_patio_light = 0
rule "Motion Light ON Patio"
Item Patio_motion changed from OFF to ON
if (NightState.state = ON){
sendCommand(Gold_lamp, ON)
counter_patio_light = 2
rule "every minute"
Time cron "0 * * * * ?"
if (counter_patio_light > 0) counter_patio_light = counter_patio_light - 1
if (counter_patio_light == 1) sendCommand(Gold_lamp, OFF)
items:
Switch Patio_motion “switch” {channel=“zoneminder:monitor:94da2af1:monitor-2:alarm”}
Logfile:
[vent.ItemStateChangedEvent] - zoneminder_monitor_94da2af1_monitor_2_force_alarm changed from OFF to ON
[vent.ItemStateChangedEvent] - zoneminder_monitor_94da2af1_monitor_2_alarm changed from OFF to ON
First thing, please always use code fences to post code, as discourse software will change some characters and the code is more readable as well.
Your code goes here
You accidentally used = instead of ==:
    if (NightState.state == ON) { // use == here
        // sendCommand(Gold_lamp, ON)
        Gold_lamp.sendCommand(ON)  //both should work, but the method should be preferred
rule "every minute"
       Gold_lamp.sendCommand(OFF)
Thank you, looks like its working!
_
