Probably I messed up the logs during my tests. I also did a test where a removed the classpath to see the difference. It looks like I uploaded that log file…
This is the correct log and here you see the log message you are referring to but also in this case the files are not loaded:
2019-05-22 09:59:23.507 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 172.25.16.46
2019-05-22 09:59:23.535 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 192.168.50.224
2019-05-22 09:59:23.576 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 10.4.41.53
2019-05-22 09:59:23.743 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 172.22.64.33
2019-05-22 09:59:30.574 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.items'
2019-05-22 09:59:32.616 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-05-22 09:59:33.257 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://10.0.75.1:8080
2019-05-22 09:59:33.259 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://10.0.75.1:8443
2019-05-22 09:59:33.666 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2019-05-22 09:59:33.798 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-05-22 09:59:33.957 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2019-05-22 09:59:33.965 [DEBUG] [org.openhab.core.automation ] - BundleEvent STARTING - org.openhab.core.automation
2019-05-22 09:59:33.971 [DEBUG] [org.openhab.core.automation ] - BundleEvent STARTED - org.openhab.core.automation
2019-05-22 09:59:33.983 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.RuleProvider, org.openhab.core.automation.ManagedRuleProvider}={service.id=364, service.bundleid=209, service.scope=bundle, component.name=org.openhab.core.automation.ManagedRuleProvider, component.id=206} - org.openhab.core.automation
2019-05-22 09:59:33.994 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.events.EventFactory}={service.id=365, service.bundleid=209, service.scope=bundle, component.name=org.openhab.core.automation.internal.RuleEventFactory, component.id=208} - org.openhab.core.automation
2019-05-22 09:59:33.998 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.handler.ModuleHandlerFactory}={service.id=366, service.bundleid=209, service.scope=bundle, component.name=org.openhab.core.automation.internal.module.factory.CoreModuleHandlerFactory, component.id=211} - org.openhab.core.automation
2019-05-22 09:59:34.008 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.handler.ModuleHandlerFactory}={service.id=367, service.bundleid=209, service.scope=bundle, component.name=org.openhab.core.automation.internal.module.handler.TimerModuleHandlerFactory, component.id=212} - org.openhab.core.automation
2019-05-22 09:59:34.051 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.parser.Parser}={service.id=368, service.bundleid=209, service.scope=bundle, parser.type=parser.module.type, component.name=org.openhab.core.automation.internal.parser.gson.ModuleTypeGSONParser, format=json, component.id=214} - org.openhab.core.automation
2019-05-22 09:59:34.058 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.parser.Parser}={service.id=369, service.bundleid=209, service.scope=bundle, parser.type=parser.rule, component.name=org.openhab.core.automation.internal.parser.gson.RuleGSONParser, format=json, component.id=215} - org.openhab.core.automation
2019-05-22 09:59:34.061 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.parser.Parser}={service.id=370, service.bundleid=209, service.scope=bundle, parser.type=parser.template, component.name=org.openhab.core.automation.internal.parser.gson.TemplateGSONParser, format=json, component.id=216} - org.openhab.core.automation
2019-05-22 09:59:34.066 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.osgi.util.tracker.BundleTrackerCustomizer}={service.id=371, service.bundleid=209, service.scope=bundle, Parser.target=(parser.type=parser.rule), Provider.target=(provider.type=bundle), component.name=org.openhab.core.automation.internal.provider.AutomationResourceBundlesTracker, component.id=217} - org.openhab.core.automation
2019-05-22 09:59:34.177 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 2, for automation bundle 'org.openhab.core.automation'
2019-05-22 09:59:34.179 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.automation.module.script.rulesupport'
2019-05-22 09:59:34.187 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.template.RuleTemplateProvider, org.eclipse.smarthome.core.common.registry.Provider}={service.id=372, provider.type=bundle, service.bundleid=209, service.scope=bundle, Parser.target=(parser.type=parser.template), component.name=org.openhab.core.automation.internal.provider.TemplateResourceBundleProvider, component.id=219} - org.openhab.core.automation
2019-05-22 09:59:34.189 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.type.ModuleTypeProvider}={service.id=373, service.bundleid=209, service.scope=bundle, Parser.target=(parser.type=parser.module.type), component.name=org.openhab.core.automation.internal.provider.file.ModuleTypeFileProviderWatcher, component.id=220} - org.openhab.core.automation
2019-05-22 09:59:34.197 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.template.RuleTemplateProvider}={service.id=374, service.bundleid=209, service.scope=bundle, Parser.target=(parser.type=parser.template), component.name=org.openhab.core.automation.internal.provider.file.TemplateFileProviderWatcher, component.id=221} - org.openhab.core.automation
2019-05-22 09:59:34.209 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.type.ModuleTypeProvider, org.openhab.core.automation.handler.ModuleHandlerFactory}={service.id=376, service.bundleid=209, service.scope=bundle, component.name=org.openhab.core.automation.internal.module.provider.AnnotatedActionModuleTypeProvider, component.id=213} - org.openhab.core.automation
2019-05-22 09:59:34.280 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.type.ModuleTypeProvider, org.eclipse.smarthome.core.common.registry.Provider}={service.id=377, provider.type=bundle, service.bundleid=209, service.scope=bundle, Parser.target=(parser.type=parser.module.type), component.name=org.openhab.core.automation.internal.provider.ModuleTypeResourceBundleProvider, component.id=218} - org.openhab.core.automation
2019-05-22 09:59:34.283 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.module.provider.i18n.ModuleTypeI18nService}={service.id=375, service.bundleid=209, service.scope=bundle, component.name=org.openhab.core.automation.internal.provider.i18n.ModuleTypeI18nServiceImpl, component.id=222} - org.openhab.core.automation
2019-05-22 09:59:34.286 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.template.TemplateRegistry, org.openhab.core.automation.internal.template.RuleTemplateRegistry}={service.id=378, service.bundleid=209, service.scope=bundle, component.name=org.openhab.core.automation.internal.template.RuleTemplateRegistry, component.id=223} - org.openhab.core.automation
2019-05-22 09:59:34.292 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.RuleManager, org.eclipse.smarthome.core.common.registry.RegistryChangeListener}={service.id=381, service.bundleid=209, service.scope=bundle, rule.reinitialization.delay=500, component.name=org.openhab.core.automation.internal.RuleEngineImpl, component.id=207} - org.openhab.core.automation
2019-05-22 09:59:34.319 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added CoreModuleHandlerFactory
2019-05-22 09:59:34.363 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added TimerModuleHandlerFactory
2019-05-22 09:59:34.364 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added AnnotatedActionModuleTypeProvider
2019-05-22 09:59:34.365 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.RuleRegistry}={service.id=380, service.bundleid=209, service.scope=bundle, component.name=org.openhab.core.automation.internal.RuleRegistryImpl, component.id=209} - org.openhab.core.automation
2019-05-22 09:59:34.384 [DEBUG] [.provider.RuleResourceBundleImporter] - Parse rules from bundle 'org.openhab.core.automation'
2019-05-22 09:59:34.388 [DEBUG] [.provider.RuleResourceBundleImporter] - Parse rules from bundle 'org.openhab.core.automation.module.script.rulesupport'
2019-05-22 09:59:34.395 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.type.ModuleTypeProvider}={service.id=383, service.bundleid=209, service.scope=singleton} - org.openhab.core.automation
2019-05-22 09:59:34.409 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.template.RuleTemplateProvider}={service.id=384, service.bundleid=209, service.scope=singleton} - org.openhab.core.automation
2019-05-22 09:59:34.414 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.io.console.extensions.ConsoleCommandExtension}={service.id=382, service.bundleid=209, service.scope=bundle, component.name=org.openhab.core.automation.internal.commands.AutomationCommandsPluggable, component.id=210} - org.openhab.core.automation
2019-05-22 09:59:34.416 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.type.ModuleTypeRegistry}={service.id=379, service.bundleid=209, service.scope=bundle, component.name=org.openhab.core.automation.internal.type.ModuleTypeRegistryImpl, component.id=224} - org.openhab.core.automation
2019-05-22 09:59:34.421 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added AnnotatedThingActionModuleTypeProvider
2019-05-22 09:59:34.426 [DEBUG] [org.openhab.core.automation ] - ServiceEvent REGISTERED - {org.openhab.core.automation.type.ModuleTypeProvider, org.openhab.core.automation.handler.ModuleHandlerFactory}={service.id=385, service.bundleid=209, service.scope=bundle, component.name=org.openhab.core.automation.thingsupport.AnnotatedThingActionModuleTypeProvider, component.id=225} - org.openhab.core.automation
2019-05-22 09:59:34.440 [DEBUG] [openhab.core.automation.module.media] - BundleEvent STARTING - org.openhab.core.automation.module.media
2019-05-22 09:59:34.440 [DEBUG] [openhab.core.automation.module.media] - BundleEvent STARTED - org.openhab.core.automation.module.media
2019-05-22 09:59:34.496 [DEBUG] [openhab.core.automation.module.media] - ServiceEvent REGISTERED - {org.openhab.core.automation.type.ModuleTypeProvider}={service.id=386, service.bundleid=210, service.scope=bundle, component.name=org.openhab.core.automation.module.media.internal.MediaActionTypeProvider, component.id=226} - org.openhab.core.automation.module.media
2019-05-22 09:59:34.500 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added MediaModuleHandlerFactory
2019-05-22 09:59:34.500 [DEBUG] [openhab.core.automation.module.media] - ServiceEvent REGISTERED - {org.openhab.core.automation.handler.ModuleHandlerFactory}={service.id=387, service.bundleid=210, service.scope=bundle, component.name=org.openhab.core.automation.module.media.internal.MediaModuleHandlerFactory, component.id=227} - org.openhab.core.automation.module.media
2019-05-22 09:59:34.503 [DEBUG] [openhab.core.automation.module.media] - ServiceEvent REGISTERED - {org.openhab.core.automation.module.script.ScriptExtensionProvider}={service.id=388, service.bundleid=210, service.scope=bundle, component.name=org.openhab.core.automation.module.media.internal.MediaScriptScopeProvider, component.id=228} - org.openhab.core.automation.module.media
2019-05-22 09:59:34.506 [DEBUG] [penhab.core.automation.module.script] - BundleEvent STARTING - org.openhab.core.automation.module.script
2019-05-22 09:59:34.507 [DEBUG] [penhab.core.automation.module.script] - BundleEvent STARTED - org.openhab.core.automation.module.script
2019-05-22 09:59:34.511 [DEBUG] [penhab.core.automation.module.script] - ServiceEvent REGISTERED - {org.openhab.core.automation.module.script.ScriptEngineFactory}={service.id=389, service.bundleid=211, service.scope=bundle, component.name=org.openhab.core.automation.module.script.internal.GenericScriptEngineFactory, component.id=229} - org.openhab.core.automation.module.script
2019-05-22 09:59:34.513 [DEBUG] [penhab.core.automation.module.script] - ServiceEvent REGISTERED - {org.openhab.core.automation.module.script.ScriptEngineFactory}={service.id=390, service.bundleid=211, service.scope=bundle, component.name=org.openhab.core.automation.module.script.internal.NashornScriptEngineFactory, component.id=230} - org.openhab.core.automation.module.script
2019-05-22 09:59:34.518 [DEBUG] [penhab.core.automation.module.script] - ServiceEvent REGISTERED - {org.openhab.core.automation.module.script.internal.ScriptExtensionManager}={service.id=391, service.bundleid=211, service.scope=bundle, component.name=org.openhab.core.automation.module.script.internal.ScriptExtensionManager, component.id=232} - org.openhab.core.automation.module.script
2019-05-22 09:59:34.519 [DEBUG] [penhab.core.automation.module.script] - ServiceEvent REGISTERED - {org.openhab.core.automation.module.script.ScriptEngineManager}={service.id=392, service.bundleid=211, service.scope=bundle, component.name=org.openhab.core.automation.module.script.internal.ScriptEngineManagerImpl, component.id=231} - org.openhab.core.automation.module.script
2019-05-22 09:59:34.549 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Added GenericScriptEngineFactory
2019-05-22 09:59:34.551 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngineFactory details for Oracle Nashorn (1.8.0_131): supports ECMAScript (ECMA - 262 Edition 5.1) with file extensions [js], names [nashorn, Nashorn, js, JS, JavaScript, javascript, ECMAScript, ecmascript], and mimetypes [application/javascript, application/ecmascript, text/javascript, text/ecmascript]
2019-05-22 09:59:34.554 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngineFactory details for jython (2.7.0): supports python (2.7) with file extensions [py], names [python, jython], and mimetypes [text/python, application/python, text/x-python, application/x-python]
2019-05-22 09:59:34.555 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Added NashornScriptEngineFactory
2019-05-22 09:59:34.556 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngineFactory details for Oracle Nashorn (1.8.0_131): supports ECMAScript (ECMA - 262 Edition 5.1) with file extensions [js], names [nashorn, Nashorn, js, JS, JavaScript, javascript, ECMAScript, ecmascript], and mimetypes [application/javascript, application/ecmascript, text/javascript, text/ecmascript]
2019-05-22 09:59:34.557 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngineFactory details for jython (2.7.0): supports python (2.7) with file extensions [py], names [python, jython], and mimetypes [text/python, application/python, text/x-python, application/x-python]
2019-05-22 09:59:34.559 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Removed GenericScriptEngineFactory
2019-05-22 09:59:34.560 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Removed NashornScriptEngineFactory
2019-05-22 09:59:34.564 [DEBUG] [penhab.core.automation.module.script] - ServiceEvent REGISTERED - {org.openhab.core.automation.module.script.ScriptExtensionProvider}={service.id=393, service.bundleid=211, service.scope=bundle, component.name=org.openhab.core.automation.module.script.internal.defaultscope.DefaultScriptScopeProvider, component.id=233} - org.openhab.core.automation.module.script
2019-05-22 09:59:34.574 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Added GenericScriptEngineFactory
2019-05-22 09:59:34.575 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngineFactory details for Oracle Nashorn (1.8.0_131): supports ECMAScript (ECMA - 262 Edition 5.1) with file extensions [js], names [nashorn, Nashorn, js, JS, JavaScript, javascript, ECMAScript, ecmascript], and mimetypes [application/javascript, application/ecmascript, text/javascript, text/ecmascript]
2019-05-22 09:59:34.576 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngineFactory details for jython (2.7.0): supports python (2.7) with file extensions [py], names [python, jython], and mimetypes [text/python, application/python, text/x-python, application/x-python]
2019-05-22 09:59:34.577 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Added NashornScriptEngineFactory
2019-05-22 09:59:34.577 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngineFactory details for Oracle Nashorn (1.8.0_131): supports ECMAScript (ECMA - 262 Edition 5.1) with file extensions [js], names [nashorn, Nashorn, js, JS, JavaScript, javascript, ECMAScript, ecmascript], and mimetypes [application/javascript, application/ecmascript, text/javascript, text/ecmascript]
2019-05-22 09:59:34.578 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngineFactory details for jython (2.7.0): supports python (2.7) with file extensions [py], names [python, jython], and mimetypes [text/python, application/python, text/x-python, application/x-python]
2019-05-22 09:59:34.579 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added ScriptModuleHandlerFactory
2019-05-22 09:59:34.580 [DEBUG] [penhab.core.automation.module.script] - ServiceEvent REGISTERED - {org.openhab.core.automation.handler.ModuleHandlerFactory}={service.id=394, service.bundleid=211, service.scope=bundle, component.name=org.openhab.core.automation.module.script.internal.factory.ScriptModuleHandlerFactory, component.id=234} - org.openhab.core.automation.module.script
2019-05-22 09:59:34.629 [DEBUG] [penhab.core.automation.module.script] - ServiceEvent REGISTERED - {org.openhab.core.automation.type.ModuleTypeProvider}={service.id=395, service.bundleid=211, service.scope=bundle, component.name=org.openhab.core.automation.module.script.internal.provider.ScriptModuleTypeProvider, component.id=235} - org.openhab.core.automation.module.script
2019-05-22 09:59:34.631 [DEBUG] [automation.module.script.rulesupport] - BundleEvent STARTING - org.openhab.core.automation.module.script.rulesupport
2019-05-22 09:59:34.632 [DEBUG] [automation.module.script.rulesupport] - BundleEvent STARTED - org.openhab.core.automation.module.script.rulesupport
2019-05-22 09:59:34.641 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added ScriptedCustomModuleHandlerFactory
2019-05-22 09:59:34.642 [DEBUG] [automation.module.script.rulesupport] - ServiceEvent REGISTERED - {org.openhab.core.automation.module.script.rulesupport.internal.ScriptedCustomModuleHandlerFactory, org.openhab.core.automation.handler.ModuleHandlerFactory}={service.id=396, service.bundleid=212, service.scope=bundle, component.name=org.openhab.core.automation.module.script.rulesupport.internal.ScriptedCustomModuleHandlerFactory, component.id=237} - org.openhab.core.automation.module.script.rulesupport
2019-05-22 09:59:34.644 [DEBUG] [automation.module.script.rulesupport] - ServiceEvent REGISTERED - {org.openhab.core.automation.module.script.rulesupport.internal.ScriptedCustomModuleTypeProvider, org.openhab.core.automation.type.ModuleTypeProvider}={service.id=397, service.bundleid=212, service.scope=bundle, component.name=org.openhab.core.automation.module.script.rulesupport.internal.ScriptedCustomModuleTypeProvider, component.id=238} - org.openhab.core.automation.module.script.rulesupport
2019-05-22 09:59:34.649 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added ScriptedPrivateModuleHandlerFactory
2019-05-22 09:59:34.650 [DEBUG] [automation.module.script.rulesupport] - ServiceEvent REGISTERED - {org.openhab.core.automation.module.script.rulesupport.internal.ScriptedPrivateModuleHandlerFactory, org.openhab.core.automation.handler.ModuleHandlerFactory}={service.id=398, service.bundleid=212, service.scope=bundle, component.name=org.openhab.core.automation.module.script.rulesupport.internal.ScriptedPrivateModuleHandlerFactory, component.id=239} - org.openhab.core.automation.module.script.rulesupport
2019-05-22 09:59:34.750 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md]}
2019-05-22 09:59:34.754 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {groovy=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/core/000_startup_delay.groovy], md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md]}
2019-05-22 09:59:34.756 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {groovy=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/core/000_startup_delay.groovy], md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md]}
2019-05-22 09:59:34.757 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {groovy=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/core/000_startup_delay.groovy], md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md], js=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/core/000_startup_delay.js]}
2019-05-22 09:59:34.760 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {groovy=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/core/000_startup_delay.groovy], md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md], js=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/core/000_startup_delay.js]}
2019-05-22 09:59:34.761 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {groovy=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/core/000_startup_delay.groovy], md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md], js=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/core/000_startup_delay.js], py=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/000_startup_delay.py]}
2019-05-22 09:59:34.766 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {groovy=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/core/000_startup_delay.groovy], md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md], js=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/core/000_startup_delay.js], py=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_DirectoryTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/000_startup_delay.py]}
2019-05-22 09:59:34.769 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {groovy=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/core/000_startup_delay.groovy], md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md], js=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/core/000_startup_delay.js], py=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_DirectoryTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/000_startup_delay.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_OsgiEventTrigger.py]}
2019-05-22 09:59:34.772 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {groovy=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/core/000_startup_delay.groovy], md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md], js=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/core/000_startup_delay.js], py=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_DirectoryTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_StartupTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/000_startup_delay.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_OsgiEventTrigger.py]}
2019-05-22 09:59:34.776 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {groovy=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/core/000_startup_delay.groovy], md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md], js=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/core/000_startup_delay.js], py=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_DirectoryTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonBindingInfoProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_StartupTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/000_startup_delay.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_OsgiEventTrigger.py]}
2019-05-22 09:59:34.781 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {groovy=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/core/000_startup_delay.groovy], md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md], js=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/core/000_startup_delay.js], py=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_DirectoryTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonBindingInfoProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonExtensionProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_StartupTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/000_startup_delay.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_OsgiEventTrigger.py]}
2019-05-22 09:59:34.782 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {groovy=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/core/000_startup_delay.groovy], md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md], js=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/core/000_startup_delay.js], py=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_DirectoryTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonBindingInfoProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonExtensionProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_StartupTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/000_startup_delay.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonItemChannelLinkProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_OsgiEventTrigger.py]}
2019-05-22 09:59:34.784 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {groovy=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/core/000_startup_delay.groovy], md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md], js=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/core/000_startup_delay.js], py=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_DirectoryTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonBindingInfoProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonExtensionProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonItemProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_StartupTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/000_startup_delay.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonItemChannelLinkProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_OsgiEventTrigger.py]}
2019-05-22 09:59:34.790 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {groovy=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/core/000_startup_delay.groovy], md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md], js=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/core/000_startup_delay.js], py=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_DirectoryTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonBindingInfoProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonExtensionProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonItemProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_StartupTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/000_startup_delay.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonItemChannelLinkProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonThingProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_OsgiEventTrigger.py]}
2019-05-22 09:59:34.793 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {groovy=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/core/000_startup_delay.groovy], md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md], js=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/core/000_startup_delay.js], py=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_DirectoryTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonBindingInfoProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonExtensionProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonItemProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_StartupTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonThingTypeProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/000_startup_delay.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonItemChannelLinkProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonThingProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_OsgiEventTrigger.py]}
2019-05-22 09:59:34.796 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {groovy=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/core/000_startup_delay.groovy], md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md], js=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/core/000_startup_delay.js], py=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_DirectoryTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonBindingInfoProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonExtensionProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonItemProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_StartupTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonThingTypeProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/000_startup_delay.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonItemChannelLinkProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonThingProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonTransform.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_OsgiEventTrigger.py]}
2019-05-22 09:59:34.798 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - in queue: {groovy=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/core/000_startup_delay.groovy], md=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/community/README.md, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/groovy/community/README.md], js=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/javascript/core/000_startup_delay.js], py=[file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_DirectoryTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonBindingInfoProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonExtensionProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonItemProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_StartupTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonThingTypeProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/000_startup_delay.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonItemChannelLinkProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonThingProvider.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/200_JythonTransform.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/core/components/100_OsgiEventTrigger.py, file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/personal/hello_world.py]}
2019-05-22 09:59:34.802 [DEBUG] [automation.module.script.rulesupport] - ServiceEvent REGISTERED - {org.openhab.core.automation.module.script.ScriptExtensionProvider}={service.id=400, service.bundleid=212, service.scope=bundle, component.name=org.openhab.core.automation.module.script.rulesupport.internal.RuleSupportScriptExtension, component.id=236} - org.openhab.core.automation.module.script.rulesupport
2019-05-22 09:59:34.811 [DEBUG] [automation.module.script.rulesupport] - ServiceEvent REGISTERED - {org.openhab.core.automation.module.script.rulesupport.shared.ScriptedRuleProvider, org.openhab.core.automation.RuleProvider}={service.id=399, service.bundleid=212, service.scope=bundle, component.name=org.openhab.core.automation.module.script.rulesupport.shared.ScriptedRuleProvider, component.id=241} - org.openhab.core.automation.module.script.rulesupport
2019-05-22 09:59:34.813 [DEBUG] [org.openhab.core.automation.rest ] - BundleEvent STARTING - org.openhab.core.automation.rest
2019-05-22 09:59:34.814 [DEBUG] [org.openhab.core.automation.rest ] - BundleEvent STARTED - org.openhab.core.automation.rest
2019-05-22 09:59:34.828 [DEBUG] [org.openhab.core.automation.rest ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.io.rest.RESTResource}={service.id=401, service.bundleid=213, service.scope=bundle, component.name=org.openhab.core.automation.rest.internal.ModuleTypeResource, component.id=242} - org.openhab.core.automation.rest
2019-05-22 09:59:34.843 [DEBUG] [org.openhab.core.automation.rest ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.io.rest.RESTResource}={service.id=402, service.bundleid=213, service.scope=bundle, component.name=org.openhab.core.automation.rest.internal.RuleResource, component.id=243} - org.openhab.core.automation.rest
2019-05-22 09:59:34.850 [DEBUG] [org.openhab.core.automation.rest ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.io.rest.RESTResource}={service.id=403, service.bundleid=213, service.scope=bundle, component.name=org.openhab.core.automation.rest.internal.TemplateResource, component.id=244} - org.openhab.core.automation.rest
When I add a newline to the hello_world.py and save, the script is loaded and starts printing every 10 seconds like it should:
2019-05-22 10:03:16.670 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'python/personal/hello_world.py'
2019-05-22 10:03:21.304 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Added ScriptEngine for language 'py' with identifier: file:/C:/Temp/OPENHA~2/conf/automation/jsr223/python/personal/hello_world.py
2019-05-22 10:03:24.952 [DEBUG] [jsr223.jython.core.triggers ] - when: target=[Time cron 0/10 * * * * ?], target_type=Time, trigger_target=cron, trigger_type=0/10 * * * * ?, old_state=None, new_state=None
2019-05-22 10:03:26.733 [DEBUG] [jsr223.jython.core.triggers ] - when: Created cron_trigger: [Cron-helloWorldCronDecorators-130c7f9e7c6811e999521183bc7018a0]
2019-05-22 10:03:26.738 [DEBUG] [jsr223.jython.core.rules ] - Added rule [Jython Hello World (cron decorators)]
2019-05-22 10:03:26.810 [DEBUG] [le.handler.GenericCronTriggerHandler] - Scheduled cron job '0/10 * * * * ?' for trigger 'Cron-helloWorldCronDecorators-130c7f9e7c6811e999521183bc7018a0'.
2019-05-22 10:03:26.814 [DEBUG] [rt.internal.loader.ScriptFileWatcher] - Script loaded: python/personal/hello_world.py
2019-05-22 10:03:30.803 [DEBUG] [e.automation.internal.RuleEngineImpl] - The trigger 'Cron-helloWorldCronDecorators-130c7f9e7c6811e999521183bc7018a0' of rule '3b1f580d-3254-4b4a-8470-d7fbb21d0f1b' is triggered.
2019-05-22 10:03:30.807 [INFO ] [Jython Hello World (cron decorators)] - Hello World!
2019-05-22 10:03:30.808 [DEBUG] [e.automation.internal.RuleEngineImpl] - The rule '3b1f580d-3254-4b4a-8470-d7fbb21d0f1b' is executed.
2019-05-22 10:03:40.805 [DEBUG] [e.automation.internal.RuleEngineImpl] - The trigger 'Cron-helloWorldCronDecorators-130c7f9e7c6811e999521183bc7018a0' of rule '3b1f580d-3254-4b4a-8470-d7fbb21d0f1b' is triggered.
2019-05-22 10:03:40.807 [INFO ] [Jython Hello World (cron decorators)] - Hello World!
2019-05-22 10:03:40.807 [DEBUG] [e.automation.internal.RuleEngineImpl] - The rule '3b1f580d-3254-4b4a-8470-d7fbb21d0f1b' is executed.
Sorry for the confusion, it was my fault…
