This rule works very well, but im sure I can simplify it.
rule "Mute the music if a Call is received"
Item Mute_Music received command ON
//Mute Music if Playing
if (Main_Zone_Power == ON && spotify_current_playing == ON || Main_Zone_Power == ON && myKodi_control == PLAY ) {
Zone_1_Mute.sendCommand("ON")
logInfo(scene, "Music Muted due to Incoming Call")
rule "Un Mute the music when the call is Idle"
Item Mute_Music received command OFF
//Un Mute Music if Playing
Zone_1_Mute.sendCommand("OFF")
logInfo(scene, "Music Un Muted due to Call Hang Up")
Can I use a variant using ‘ELSE’ somewhere or do I need two rules because I have an item on and off state?
Like so? I guess this wouldnt work, because the Mute needs to be off, only if the Mute_Music item is OFF
else
if (receivedCommand == ON) {
} else if (receivedCommand == OFF) {
You could shorten it more if you skip the logInfo.
Zone_1_Mute.sendCommand(receivedCommand.toString)
I’m pretty sure that your rule won’t work, as you didn’t use the state.
The rule should be more like:
rule "Mute and unmute the music in case of a Call"
if (Main_Zone_Power.state == ON && (spotify_current_playing.state == ON || myKodi_control.state == PLAY )) {
Zone_1_Mute.sendCommand(receivedCommand)
logInfo("mute",if(receivedCommand == ON) "Music muted due to Incoming Call" else "Music unmuted due to Call Hang Up")
In question of logging… this:
is the same as
logInfo("mute","Music muted due to Incoming Call")
else
logInfo("mute","Music unmuted due to Call Hang Up")
