hi,
used version 1.8.3
i want to simulate a relais-control in openhab.
background: i do have my own homecontrol with some µCs and i2c MCP-devices controled via mqtt.
before, i hard-coded every gpio-output to the correspondending ports.
now, i want the same more dynamicaly and send the µCs commands to set gpio to input or output.
for security reasons i use two relais for one rolloshutter. one for on/off, and one for direction.
so i coded a rule, which do this stuff …
but now i want to know, if there is another more compact way to do this. what i did not want is a highend java-like crypto code where a java-noob like me do see nothing more than a kind of ascii-table …
i also want to have some security, that nobody could do the same stuff, during execution of rule.
but, if i pressed i.e. UP but i wanted to press DOWN, than i should have to be able to do this …
are there any advices out there?
String ardu02_20_out_10_06_stat "Status (ardu02-20-10-06) [%s]" <info> { mqtt="<[mosquitto_cubie:i2c/stat/pinout/20/13/6:state:default]" }
Rollershutter ardu02_20_out_10_07 "Schalten (ardu02-20-10-07)" <light>
String ardu02_20_out_10_07_stat "Status (ardu02-20-10-07) [%s]" <info> { mqtt="<[mosquitto_cubie:i2c/stat/pinout/20/13/7:state:default]" }
Switch item=ardu02_20_out_10_07
Text item=ardu02_20_out_10_06_stat
Text item=ardu02_20_out_10_07_stat
this code is working, but it seemed to me as a little bit to long, especially if i want to add a lot of them …
var int lockUDS_ardu02_20_out_10_07 = 0
rule "rule_ardu02_20_out_10_07_receive_update_UP"
Item ardu02_20_out_10_07 received command UP
logInfo("rule_ardu02_20_out_10_07_updated.rule", "UP: START: rule_ardu02_20_out_10_07_receive " + lockUDS_ardu02_20_out_10_07)
while (lockUDS_ardu02_20_out_10_07 != 0)
Thread::sleep(5);
lockUDS_ardu02_20_out_10_07 = 3
publish("mosquitto_cubie", "i2c", "pinout:20:13:6:0")
while (ardu02_20_out_10_06_stat.state == "1")
Thread::sleep(5)
if (ardu02_20_out_10_06_stat.state == "0" && lockUDS_ardu02_20_out_10_07 == 3)
Thread::sleep(250)
publish("mosquitto_cubie", "i2c", "pinout:20:13:7:1")
Thread::sleep(250)
publish("mosquitto_cubie", "i2c", "pinout:20:13:6:1")
else if (ardu02_20_out_10_06_stat.state != "0")
logInfo("rule_ardu02_20_out_10_07_updated.rule", "UP: Pin 6 bleibt 1, Frage, warum")
else
logInfo("rule_ardu02_20_out_10_07_updated.rule", "UP: Lock hat nicht funktioniert")
logInfo("rule_ardu02_20_out_10_07_updated.rule", "UP: ENDE: rule_ardu02_20_out_10_07_receive " + lockUDS_ardu02_20_out_10_07)
rule "rule_ardu02_20_out_10_07_receive_update_DOWN"
Item ardu02_20_out_10_07 received command DOWN
logInfo("rule_ardu02_20_out_10_07_updated.rule", "DOWN: START: rule_ardu02_20_out_10_07_receive: " + lockUDS_ardu02_20_out_10_07)
Thread::sleep(5);
lockUDS_ardu02_20_out_10_07 = 2
Thread::sleep(5)
if (ardu02_20_out_10_06_stat.state == "0" && lockUDS_ardu02_20_out_10_07 == 2)
Thread::sleep(250)
publish("mosquitto_cubie", "i2c", "pinout:20:13:7:0")
Thread::sleep(250)
logInfo("rule_ardu02_20_out_10_07_updated.rule", "DOWN: Pin 6 bleibt 1, Frage, warum")
else
logInfo("rule_ardu02_20_out_10_07_updated.rule", "DOWN: Lock hat nicht funktioniert")
logInfo("rule_ardu02_20_out_10_07_updated.rule", "DOWN: ENDE: rule_ardu02_20_out_10_07_receive: " + lockUDS_ardu02_20_out_10_07)
rule "rule_ardu02_20_out_10_07_receive_update_STOP"
Item ardu02_20_out_10_07 received command STOP
logInfo("rule_ardu02_20_out_10_07_updated.rule", "STOP: START: rule_ardu02_20_out_10_07_receive; " + lockUDS_ardu02_20_out_10_07)
Thread::sleep(250)
logInfo("rule_ardu02_20_out_10_07_updated.rule", "STOP: ENDE: rule_ardu02_20_out_10_07_receive: " + lockUDS_ardu02_20_out_10_07)
if i only use a switch-item, this works like expected, but i do not get it to work with rollershutter-item.
rule "rule_ardu02_20_out_10_07_receive_update"
Item ardu02_20_out_10_07 received command UP or
Item ardu02_20_out_10_07 received command DOWN or
logInfo("rule_ardu02_20_out_10_07_updated.rule", "rule_ardu02_20_out_10_07_receive_update: " + ardu02_20_out_10_07.state.toString())
publish("mosquitto_cubie", "BB55/hctl/v1/ardu02/sub/i2c", "pinout:20:13:6:0")
logInfo("rule_ardu02_20_out_10_07_updated.rule", "Warten auf 6 = 0")
Thread::sleep(5)
if (ardu02_20_out_10_06_stat.state == "0")
logInfo("rule_ardu02_20_out_10_07_updated.rule", "Wir dürfen schalten")
if (ardu02_20_out_10_07.state == UP)
logInfo("rule_ardu02_20_out_10_07_updated.rule", "und schalten 7 auf 1 UP")
Thread::sleep(500)
Thread::sleep(500)
else if (ardu02_20_out_10_07.state == DOWN)
logInfo("rule_ardu02_20_out_10_07_updated.rule", "und schalten 7 auf 0 DOWN")
Thread::sleep(500)
Thread::sleep(500)
else
logInfo("rule_ardu02_20_out_10_07_updated.rule", "und schalten 7 auf 0")
Thread::sleep(500)
else
logInfo("rule_ardu02_20_out_10_07_updated.rule", "Pin 6 bleibt 1, Frage, warum")
at last, i need an advice how to lock them against re-start again. so if the shutter is set to UP, only STOP and DOWN have to work. (for now i only “lock” against UP/DOWN simultaneously)
but keep in mind, i need a lot of this rules.
this moring i got an idea, i send off to port 6, and i have to wait, that this port is down and the µC replies this, if not, nothing could be changed. i came up with the idea to do this in a for-loop, for maybe 10 times with 100ms wait between. is it good idea?
