Good day OpenHab community!
It seems I have some strange issue, but maybe this is “by design”. I have few MQTT clients. They read specified topics and writes data back. For example, I want to control music box from openhab. I want to trigger “enable” switch in openhab UI and listen music (it works). But when the music stops it should trigger switch back to OFF state. Here I have a tricky situation. It works, the switch goes to disabled (OFF) state but to see the actual result I need to refresh openhab UI page. Is it possible to do updates automatically?
.Item
Switch Music_background_enabled "Enabled [%s]" {mqtt=">[OpenHab:quest/room1/music/background_enabled:command:ON:1], >[OpenHab:quest/room1/music/background_enabled:command:OFF:0], <[OpenHab:quest/room1/music/background_enabled:state:ON:1], <[OpenHab:quest/room1/music/background_enabled:state:OFF:0]"}
.Sitemap
sitemap room1 label="Room"
Frame label="Sound"
Frame label="Background"
Slider item=Music_background_volume
