Hi, I’m trying to understand the stance ways of Openhab2. In home builder I build a virtual very small home en used the copy button to move the code in sitemaps into Visual Studio. So far so good. I put the code here between Blokquotes. The problem is that this sitemap is not being accepted and results in an error. I hope that somebody want’s to give me an answer and can clarify the mist in front of my Eyes
Blockquote
2020-07-16 14:55:46.426 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘herwijnen.sitemap’ has errors, therefore ignoring it: [7,5]: required (…)+ loop did not match anything at input ‘}’ [9,5]: missing EOF at ‘Frame’
Blockquote
Blockquote
sitemap herwijnen label=“herwijnen” {
Frame label=“Outside” icon=“garden” {
Group item=OU_Balcony
Frame label="First Floor" icon="firstfloor" {
Frame {
Text label="Humidity" icon="humidity" {
Default item=OU_Balcony_Humidity label="Balcony"
Text label="Power Outlet" icon="poweroutlet" {
Default item=OU_Balcony_Power label="Balcony"
Blockquote
