I’m a total noob, haven’t coded in my life. I’ve set up openhab2 and have got to the stage where I’m trying to create my first sitemap (default.sitemap). However, when I go to Basic UI, it doesn’t show the sitemap I’ve created. I am running this on a windows laptop.
I’ve created the default.sitemap and default.items via windows explorer (new text file then naming it default.sitemap), is this the right way to add a file for openhab2 to read it?
There are a number of things that has to be correct for the sitemap to work.
Please check that your windows editor have not added another extension to the file (like default.sitemap.txt) and that you have put the sitemap file in the sitemap folder. If that does not work, please post you sitemap and items file(s) and we can all have a look.
@hr3 you might be interested in Home Builder UI from openHAB. Simply install it along with Basic UI and Paper UI.
You can easily create your sitemap and items file with it.
@hr3 this what I have in the logs:
2018-01-08 22:26:17.904 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.1.6:8080
2018-01-08 22:26:18.100 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.1.6:8443
2018-01-08 22:26:22.190 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-01-08 22:26:22.223 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2018-01-08 22:26:22.266 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-01-08 22:26:22.304 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-01-08 22:26:22.324 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-01-08 23:06:05.178 [WARN ] [e.sshd.server.channel.ChannelSession] - Unknown pty opcode value: 42
Install openHAB under Windows is quick and easy.
So I would do a new (second) install and select Demo at initial Setup.
It’s a easy way to get a running example and a basis for own changes.
So I re-installed openHAB with demo and that seems to work.
My problem was that I was creating files “default.items” but windows was saving them as “default.items.txt”.
For anyone in future facing the same issue, simply save the file with quotation marks at the location desired “default.items” and it will save the file as a .items file type.
