Hi all !
I have an SMA inverter at home and I communicate with it through modbus.
As you can see in the images, the Openhab code rounds up the obtained values (I have no digits after the decimal. Only a zero). In other words, I would like Openhab to show me 11.6 kWh rather than 12 kWh (compared to the example)
I can’t find the parameter needed to show the exact (unrounded) value.
Can anyone help me?
Item :
Number:Energy inverter1DailyYield "Rendement du jour de l'onduleur [%.1f kWh]" <line> (Inverter1, gsavedatamidnight) ["Measurement", "Energy"] {channel="modbus:data:inverter1:Yield:Day_Yield:number"}
Sitemap :
Frame label="Rendement" {
Text item=inverter1DailyYield
