I use OH2 on Windows .I created 2 files demo.items(C:\openhab2\conf\items)and demo.sitemap(C:\openhab2\conf\sitemaps).But when i go to basicUI, It does not show my demo interface and show "It seems like you have not defined any sitemaps yet. To build one, please check the documentation for guidance. ".I don’t know what happened to me, everyone help me
Demo.items:
Switch Light “Light”
Number Temperature “Temperature [%.1f C]”
Demo.sitemap:
sitemap demo label=“Demo Sitemap” {
Frame label=“Control Panel” {
Switch item=Light
Frame label=“Monitor Panel” {
Text item=Temperature
Hi allen
I just learned about OH2 so I don’t have much experience, can you help me?and show me my mistake.Please
Can you fix 2 demo files for me to run the interface?
If possible, you can give me the Testmap.Items file for me to try on my computer
I went to openhab.log and it shows up.I do not know how. can you help me, please
2020-05-05 20:01:45.747 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-05-05 20:01:46.627 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.0.106:8080
2020-05-05 20:01:46.630 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.0.106:8443
2020-05-05 20:01:47.504 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2020-05-05 20:01:47.547 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2020-05-05 20:01:47.605 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2020-05-05 20:01:48.535 [INFO ] [roker.internal.EmbeddedBrokerService] - Broker persistence file: mqttembedded.bin
2020-05-05 20:01:49.890 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to ‘localhost’ with clientid embedded-mqtt-broker
2020-05-05 20:01:50.244 [WARN ] [lipse.smarthome.io.net.exec.ExecUtil] - Execution failed (Exit value: -559038737. Caused by java.io.IOException: Cannot run program “arping” (in directory “.”): CreateProcess error=2, The system cannot find the file specified)
2020-05-05 20:01:50.305 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2020-05-05 20:01:50.520 [WARN ] [lipse.smarthome.io.net.exec.ExecUtil] - Execution failed (Exit value: -559038737. Caused by java.io.IOException: Cannot run program “arping” (in directory “.”): CreateProcess error=2, The system cannot find the file specified)
2020-05-05 20:01:50.616 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:broker
2020-05-05 20:01:50.621 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:topic
2020-05-05 20:01:50.622 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:message
2020-05-05 20:01:50.636 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2020-05-05 20:01:50.636 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection ‘broker’
2020-05-05 20:01:52.789 [ERROR] [penhab.io.transport.mqtt.MqttService] - Error starting broker connection
org.eclipse.paho.client.mqttv3.MqttException: Unable to connect to server
at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:79) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:650) ~[?:?]
at java.lang.Thread.run(Unknown Source) [?:1.8.0_191]
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method) ~[?:1.8.0_191]
at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source) ~[?:1.8.0_191]
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source) ~[?:1.8.0_191]
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source) ~[?:1.8.0_191]
at java.net.AbstractPlainSocketImpl.connect(Unknown Source) ~[?:1.8.0_191]
at java.net.PlainSocketImpl.connect(Unknown Source) ~[?:1.8.0_191]
at java.net.SocksSocketImpl.connect(Unknown Source) ~[?:1.8.0_191]
at java.net.Socket.connect(Unknown Source) ~[?:1.8.0_191]
at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:70) ~[?:?]
… 2 more
2020-05-05 20:02:16.593 [ERROR] [io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: not authorized
2020-05-05 20:13:05.735 [ERROR] [io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: {}
io.socket.engineio.client.EngineIOException: websocket error
at io.socket.engineio.client.Transport.onError(Transport.java:63) [bundleFile:?]
at io.socket.engineio.client.transports.WebSocket.access$400(WebSocket.java:24) [bundleFile:?]
at io.socket.engineio.client.transports.WebSocket$1$5.run(WebSocket.java:107) [bundleFile:?]
at io.socket.thread.EventThread$2.run(EventThread.java:80) [bundleFile:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:1.8.0_191]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:1.8.0_191]
Caused by: java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method) ~[?:1.8.0_191]
at java.net.SocketInputStream.socketRead(Unknown Source) ~[?:1.8.0_191]
at java.net.SocketInputStream.read(Unknown Source) ~[?:1.8.0_191]
at sun.security.ssl.InputRecord.readFully(Unknown Source) ~[?:1.8.0_191]
at sun.security.ssl.InputRecord.read(Unknown Source) ~[?:1.8.0_191]
at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source) ~[?:1.8.0_191]
at sun.security.ssl.SSLSocketImpl.readDataRecord(Unknown Source) ~[?:1.8.0_191]
at sun.security.ssl.AppInputStream.read(Unknown Source) ~[?:1.8.0_191]
at okio.Okio$2.read(Okio.java:139) ~[?:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:237) ~[?:?]
at okio.RealBufferedSource.request(RealBufferedSource.java:67) ~[?:?]
at okio.RealBufferedSource.require(RealBufferedSource.java:60) ~[?:?]
at okio.RealBufferedSource.readByte(RealBufferedSource.java:73) ~[?:?]
at okhttp3.internal.ws.WebSocketReader.readHeader(WebSocketReader.java:113) ~[?:?]
at okhttp3.internal.ws.WebSocketReader.processNextFrame(WebSocketReader.java:97) ~[?:?]
at okhttp3.internal.ws.RealWebSocket.loopReader(RealWebSocket.java:262) ~[?:?]
at okhttp3.internal.ws.RealWebSocket$2.onResponse(RealWebSocket.java:201) ~[?:?]
at okhttp3.RealCall$AsyncCall.execute(RealCall.java:141) ~[?:?]
at okhttp3.internal.NamedRunnable.run(NamedRunnable.java:32) ~[?:?]
… 3 more
2020-05-05 20:13:05.742 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 786f0042-b786-4453-b55d-82e42cf73cef, base URL = http://localhost:8080)
2020-05-05 20:14:02.804 [ERROR] [io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: not authorized
2020-05-05 20:24:30.608 [ERROR] [io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: {}
… 3 more
2020-05-05 20:24:30.614 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 786f0042-b786-4453-b55d-82e42cf73cef, base URL = http://localhost:8080)
2020-05-05 20:24:47.379 [ERROR] [io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: not authorized
2020-05-05 20:24:57.386 [ERROR] [io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: {}
io.socket.engineio.client.EngineIOException: xhr poll error
at io.socket.engineio.client.transports.PollingXHR.access$100(PollingXHR.java:26) [bundleFile:?]
at io.socket.engineio.client.transports.PollingXHR$6$1.run(PollingXHR.java:140) [bundleFile:?]
at okio.RealBufferedSource.indexOf(RealBufferedSource.java:345) ~[?:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:217) ~[?:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:211) ~[?:?]
at okhttp3.internal.http1.Http1Codec.readResponseHeaders(Http1Codec.java:189) ~[?:?]
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:75) ~[?:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:92) ~[?:?]
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:45) ~[?:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:67) ~[?:?]
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:93) ~[?:?]
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[?:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:120) ~[?:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:185) ~[?:?]
at okhttp3.RealCall$AsyncCall.execute(RealCall.java:135) ~[?:?]
… 3 more
2020-05-05 20:24:57.393 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 786f0042-b786-4453-b55d-82e42cf73cef, base URL = http://localhost:8080)
2020-05-05 20:25:31.085 [ERROR] [io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: not authorized
You’ve got a problem with your MQTT broker connection, that doesn’t matter for your sitemap.
You’ve got a problem with your myOpenhab cloud connection, that doesn’t matter for your sitemap.
You’ve shown us no Loading model 'xxx.sitemap'
mesages, so either they come later in your log, or the filename(s) do not end in .sitemap, or they are in the wrong folder instead of /sitemaps
Well, you could further down in your openhab.log to see if there are any messages about your sitemap.
If they are really not there, then you’d need to look to see where you put your file Demo.sitemap, and to check if it is really called Demo.sitemap and not something like Demo.sitemap.txt, which people sometimes manage to do by accident with the editor they have chosen.
Even if it contains rubbish, openHAB would try to load any file of the form xxx.sitemap from your folder /conf/sitemaps and log a message.
I saw the file openhab.log but I did not see the message about the sitemap.
I checked the location of the 2 files demo.items(C:\openhab2\conf\items)and demo.sitemap(C:\openhab2\conf\sitemaps) and no files Demo.sitemap.txt and there is no xxx.sitemap file elsewhere
Are you really, really sure? Windows is quite good at hiding filename extensions by default. Right click and check properties.
There will be a readme.txt file in that folder too, how does that appear?
