My Openhab2 System has been running very well now for well over two months now , that was until this morning. I am running a Lubuntu Os and it asked me if I wanted to install the update so , stupid me, I said yes. After the update Openhab cant see the home.sitemap file. I did not change anything in the settings.
If I run Habpanel my Items is still there but the moment I open the classic page I get
"javax.servlet.ServletException: Sitemap ‘home’ could not be found"
The sitemap file is located in the /etc/openhab2/sitemaps folder with the name home.sitemap
The owner and group is openhab so I just dont know what else I am missing.
Any Ideas ?
Best regards
Paul
Hello Paul from South Africa! It’s just amazing to see people from all over the world using openHAB.
My first guess would be there is a syntax error in your sitemap file. In that case this would be the normal behavior. With openHAB 2.1 the config file validation got a bit stricter, you “slightly incorrect” sitemap could now be seen as wrong.
Check the openhab.log for errors related to your sitemap. This might be close: grep "home.sitemap" /var/log/openhab2/openhab.log
2017-07-25 18:23:16.144 [WARN ] [eclipse.jetty.servlet.ServletHandler] -
javax.servlet.ServletException: Sitemap 'home' could not be found
at org.eclipse.smarthome.ui.classic.internal.servlet.WebAppServlet.service(WebAppServlet.java:169)[197:org.eclipse.smarthome.ui.classic:0.9.0.b5]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812)[81:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587)[81:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)[172:org.ops4j.pax.web.pax-web-jetty:4.3.0]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)[79:org.eclipse.jetty.security:9.2.19.v20160908]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:287)[172:org.ops4j.pax.web.pax-web-jetty:4.3.0]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)[81:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)[172:org.ops4j.pax.web.pax-web-jetty:4.3.0]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.Server.handle(Server.java:499)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)[71:org.eclipse.jetty.io:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at java.lang.Thread.run(Thread.java:748)[:1.8.0_131]
Caused by: org.eclipse.smarthome.ui.classic.render.RenderException: Sitemap 'home' could not be found
at org.eclipse.smarthome.ui.classic.internal.servlet.WebAppServlet.service(WebAppServlet.java:130)[197:org.eclipse.smarthome.ui.classic:0.9.0.b5]
... 21 more
Ok as you predicted Smarthome Designer showed that there were a couple of silly syntax errors in my sitemap , all were “{” errors. Atleast now I know of Smarthome Designer so I will not need to work with note pad again .
