If i change the status of a a selection item in my sitemap (ios) sometimes the status is reflected in the sitemap instantly, sometimes it takes about 20-30 seconds until it shows up.
In parallel the status is updated instantly showing the correct item state in the semantic model in the oh3 webinterface.
The item was created in the semantic model as equipment. just as a proxy item.
Then stateDescription metadata with following options was added:
Switching the options in the semantic model is working flawless.
In the Sitemap I added this item as Selection (or also tested as Default) and the options are showing correctly but about each second change the status is delayed about half a minute.
Manually updating the sitemap with a swipe of my finger on my iphone instantly updates to the correct status.
Thanks for your answer but that post doesn’t describe my problem.
The sitemap works flawless with more than 50 items. The only strange behaving is with this lazy status update delay on the proxy item with many status options. switches etc everything else works as expected.
