I’ve got an annoying issue with my sitemap.
Most of the time, it’s not refreshing as expected. A bit hard to see an up to date status of a switch.
- When I fe change a switch to ON, I see it jumping to ON, and directly to OFF again. (or vice versa).
- The light goes to ON. (no difference with KNX, zwave or shelly devices).
- When I refresh the page, the switch is changed to ON. (webbrowser or android app are acting same)
- It has the same behavoir when I connect to openhab directly, nginx or over the cloud myopenhab.org.
Any hint where I should look?
- Can this be linked to a ‘to big’ sitemap (currently 1900 lines)?
- To much items (currently 2900 lines)?
- Server issues (virtual machine on dell server, plenty of resources)?
- I currently use openhab 3.1.0 (stable version).
All suggestion are welcome!!!
