sitemap pjw_home label="PJW Home" {
Frame label="First Floor" icon="firstfloor" {
Group item=FF_LivingDining
Group item=FF_Toilet
Group item=FF_Kitchen
Group item=FF_FrontYard
Group item=FF_Outside
Group item=FF_LaundryRoom
Frame label="Second Floor" icon="attic" {
Group item=F2_MasterBedroom
Group item=F2_Bedroom1
Group item=F2_Bedroom2
Group item=F2_Bedroom3
i also tried to continue with homebuilder, but it starts from scratch.
for the initial install, i have an esp8266 device, recognized by mqtt server, but trying to find it, did not work.
I installed the mqtt bindings, but openhab seams not to find it.
1557345105: New connection from 192.168.1.5 on port 1883.
1557345105: New client connected from 192.168.1.5 as ESPClient_EC:FA:BC:23:87:DC (c1, k10, u'').
1557345163: Client ESPClient_EC:FA:BC:23:87:DC disconnected.
1557345171: New connection from 192.168.1.5 on port 1883.
1557345171: New client connected from 192.168.1.5 as ESPClient_EC:FA:BC:23:87:DC (c1, k10, u'').
1557345303: New connection from 192.168.1.6 on port 1883.
1557345303: New client connected from 192.168.1.6 as paho10800054946750 (c1, k60).
1557345352: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
what could be wrong? sorry it it seams too basic, but as told, an absolute beginner on openhab and some of the docs are not so easy to understand.
Name MQTT Broker
Broker Histname/IP
192.168.1.6
Client ID
paho10800054946750 (as log shows 1557345303: New client connected from 192.168.1.6 as paho10800054946750 (c1, k60))
Have it all… but the thing is not being discovered
yes, i have the mqtt broker (mosquitto) already installed, and it talks to my thing - 1557423113: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1557424914: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1557425022: Client ESPClient_EC:FA:BC:23:87:DC disconnected.
1557425029: New connection from 192.168.1.5 on port 1883.
If the mqtt binding is installed, the next step would be to create a mqtt broker thing which establishes the connection between mosquitto and openhab.
After that either the autodicovery should work or you could create the Generic mqtt things.
I used the later only, so this is how far I could guide you.
I am just learning MQTT with OH2 at the moment and i do recall reading in the documentation for this binding [HERE] that auto discovery only works for MQTT Homie and HomeAssistant bindings.
I am using a generic MQTT thing and i have to set it up manually.
