Sitemap suddenly not seen
  • Platform information:
    • Hardware: _Raspberry Pi 3 Model B
    • OS: _Openhabian
    • openHAB version: 3
  • Issue of the topic:
    Sitemap that was working is suddenly not found. I had my whole setup working just perfect and then suddenly the APP (Android) cant find the sitemap, no changes made to it at all either between working and not working. I created new blank sitemap named test and that works fine although its blank. Anyone else seen this? Same issue if using the OpenHAB or the OpenHABBeta App as well.
Try adding a syntax error on purpose (for example by removing a bracket) and save. Then, after some seconds, remove the syntax error again and save. With this openHAB will reload the file. This often helped me in the past
I have tried that and get nothing at all. When I go to
http://xx.xx.xx.xx:8080/rest/sitemaps all am I getting is
And in the App just getting OpenHAB Returned empty sitemap list. I created a new sitemap and still getting exactly the same message.
what do your logs say?
Does openHAB have read access to the sitemaps?
Hi yeah they do, cant see anything in the logs in /var/log/openhab at all.
