OH3
Ubuntu 20.04
Just started playing around with OH3.
I made a site map from the “Pages” area under settings.
Just curious why it says “UIcomponents_” in front of the site map name?
OH3
Ubuntu 20.04
I’ve not tried to build a sitemap through the UI but I suspect that the UIcomponents part will be there for any sitemap built through MainUI.
Is there a way to remove “UIComponents_” from the sitemap URL?
You can edit the filename, but will no longer be able to use the GUI editor I think.
VSCode editor with openhab extension supports sitemap syntax.
