SkyQ Binding
This binding provides control and status information functions for SkyQ receivers.
Supported Things
SkyQ receiver.
Discovery
Currently no discovery is implemented
Thing Configuration
Use the UI to add the receiver as a thing and provide the following configuration options
Parameter | Required | Default | Description |
Hostname |
yes | N/A | The IP address of the SkyQ receiver to control |
MAC Address |
no | “” (empty string) | The MAC address of the SkyQ receiver to control |
Enable Configurable Preset |
no | true | Enables the configuration of the channel preset (see below) |
Refresh Interval |
yes | 30 | The interval for refreshing the item states in seconds |
Retry Polling |
yes | 60 | The interval for retrying the connection to the recevier after it went offline |
Status Check Interval |
yes | 60 | The interval for checking if the receiver is reachable (online) |
Channels
Channel | Type | Description |
control#controlCommand | String | Sends a remote control command to the device (see below) |
control#channelPreset | String | Holds list of channels from receiver and allows switch to a selected channel. The list and order of the channels can be configured through a file (see below). |
control#channelFavorites | String | Holds list of favorite channels from receiver and allows switch to a selected channel. |
control#power | Switch | Switches the receiver ON or OFF. The receiver has to be in standby mode for this to work. |
statusChannels#currentChannelTitle | String | Shows current live TV channel title if available |
statusChannels#powerStatus | String | Shows power state ON, OFF, or STANDBY |
statusChannels#currentTransportState | String | State of current transport stream (PLAYING etc) |
Control commands
The control#controlCommand
channel supports the following commands that are defined as state options:
Value | Label | Description |
power | Power | |
select | Select | |
backup | Back/Up | |
dismiss | Dismiss | |
channelup | Channel up | |
channeldown | Channel down | |
interactive | Interactive | |
sidebar | Sidebar | |
help | Help | |
services | Services | |
search | Search | |
tvguide | TV guide | |
home | Home | |
i | i | |
text | Text | |
up | Up | |
down | Down | |
left | Left | |
right | Right | |
red | Red | |
green | Green | |
yellow | Yellow | |
blue | Blue | |
0 | 0 | |
1 | 1 | |
2 | 2 | |
3 | 3 | |
4 | 4 | |
5 | 5 | |
6 | 6 | |
7 | 7 | |
8 | 8 | |
9 | 9 | |
play | Play | |
pause | Pause | |
stop | Stop | |
record | Record | |
fastforward | Fast forward | |
rewind | Rewind | |
boxoffice | Box office | |
sky | Sky |
Defining macros
The controlCommand
channel supports sending multiple commands to the device. This allows the definition of macros by the following procedure:
- Define a
String
typed item linked to thecontrolCommand
channel - Add
State Description
metadata to the item - A macro is defined by each option (line) within the
Options
section. The option value represents the semicolon separated sequence of commands of the macro, and the label the macro name. - A special command
sleep
is used to delay the sending of the commands by a fixed but short period. This might be required for certain sequences of commands because sometime some commands are swallowed by the box.
Example
State options that define macros for opening the prime video app of for showing the top series page
interactive;down;down;down;select=prime video
home;sleep;down;down;down;sleep;right;right=Top Series
Note the sleep
command here which is required to get reproducable results.
Configurable channel presets
To ease the selection of a large number of TV preset channels, the channels for selection can be filtered and sorted by use of a configuration file.
This feature can be enabled by setting the thing configuration Enable Configurable Presets
and saving the new configuration.
If this feature is enabled, the complete channel list as requested from the receiver on each initialization will be stored
as a csv formatted file /userdata/config/skyq/channel_presets.csv
To filter and sort the channels list, edit the file and set the value of the last column named Rank
as follows:
Rank value | Effect |
< 0 |
channel is excluded |
0 |
channel is added to end of preset list |
> 0 |
channel is added in the order of the rank value |
Channels with same rank value will be ordered by the display number.
A refresh of the preset channels after a change of the csv file can be triggered by issuing the command --REFRESH--
which is added as first
pseudo channel to the list.
Full Example
skyq.things:
Thing skyq:skyqreceiver:skyq1 [ hostname="192.168.1.2", configurablePresets=true, retryInterval=60, checkStatusInterval=60, refreshInterval=30 ]
skyq.items:
String sky_command "[%s]" {channel="skyq:skyqreceiver:skyq1:control#controlCommand"}
Main UI Examples
Control command cell
When clicked, a control command is send to the receiver on selection from a drop down list
YAML definition of cell
component: oh-label-cell
action: options
actionItem: SkyQReceiver_ControlReceiverCommand
expandable: false
item: SkyQReceiver_ControlReceiverCommand
stateAsHeader: true
title: Control Receiver Comman
Preset cell
When clicked, a custom widget is opened with a list of the possibly filtered and ordered list of channels.
This list can be further filtered. On selection of a channel item, the receiver will switch to this channel.
action: popup
actionModal: widget:widget_tv_preset
actionModalConfig:
item: SkyQReceiver_ChannelPreset
prop1: Select channel
expandable: false
title: TV Channel
YAML definition of custom widget
uid: widget_tv_preset
tags: []
props:
parameters:
- description: A text prop
label: Prop 1
required: false
type: TEXT
- context: item
description: An item to control
label: Item
required: false
type: TEXT
parameterGroups: []
timestamp: Nov 19, 2021, 5:34:29 PM
component: f7-card
title: =props.prop1
slots:
default:
- component: f7-list
virtualList: true
slots:
before-list:
- component: oh-input-item
icon: f7:search
iconColor: gray
outline: true
placeholder: Suche
type: text
variable: channelFilter
default:
- component: oh-repeater
filter: loop.option.label.toLowerCase().includes(vars.channelFilter.toLowerCase()) == true
for: option
fragment: true
itemOptions: =props.item
sourceType: itemStateOptions
slots:
default:
- component: oh-list-item
action: command
actionCommand: =loop.option.value
actionItem: =props.item
popupClose: true
title: =loop.option.label
Changelog
Version 3.4.0
- Improved power on/off handling
- Fixed issues with non-refreshing states
- Added macro feature for control commands
Version 3.2.0-1
- Fixes issues with up command not working
Version 3.2.0
- Initial stable release
