Using openHab 1.8 with InsteonPLM binding. Everything is working well so far except the Sliders in the UI. If I setup the dimmer as a switch, the switch works fine in the UI and toggles the light on/off. However, if I change this to a dimmer, I get a slider and cannot change the level of the slider. If I manually set the light levels via the Insteon app, the slider updates to represent the light level. I just can’t use it as an input!
Here is my item:
Dimmer mainHallLights “Ceiling Lights” (GF_Hall) {insteonplm = “2F.D5.DF:F00.00.01#dimmer,related=2D.46.05”}
Here is my sitemap for the item:
Frame label="Hall" {
Text label="Hall Test" icon="firstfloor" {
Slider item=mainHallLights switchSupport
Hoping this is just a simple issue that I’ve missed!
Thanks, Chris
