It would be great if someone could post an example for text file configuration (*.things and *.items) in order to get an overview how to set it up with smaenergymeter binding.
I’ll get an SMA Energy Meter (Sunny Home Manager 2.0) with 2x Sunny Boy 3.0 connected.
Pls note that energy meter and Home Manager are different things.
Have a look at http://storm.house/energiemanagement-system/
It does more or less what the Home Manager does, but implemented in openHAB so you can tweak it yourself, for about the same price.
Granted I haven’t adapted it to a SMA box but would support you with that part for free.
usually you do not need a .things text file configuration (at least I never tried it with my SMA Energy Meter). There are 3 parameters (IP Multicast address, Port and Timeout) - but these are usually all the same for all SMA Energy Meters as factory default (IP: 239.12.255.254, Port 9522).
The EM will be automatically discovered as long as no-one changes the factory defaults.
If you want to create your own items file - here is the pattern (the serial number becomes the thing-ID):
// SMA Energymeter
Number PV_Power_In "Bezogene Leistung" <energy> (CHART, PV_Power_Chart) { channel = "smaenergymeter:energymeter:190023xxxx:powerIn" }
Number PV_Power_Out "Eingespeiste Leistung" <energy> (CHART, PV_Power_Chart) { channel = "smaenergymeter:energymeter:190023xxxx:powerOut" }
Number PV_Energy_In "Bezogene Energie" <energy> (CHART) { channel = "smaenergymeter:energymeter:190023xxxx:energyIn" }
Number PV_Energy_Out "Eingespeise Energie" <energy> (CHART) { channel = "smaenergymeter:energymeter:190023xxxx:energyOut" }
