I am not sure what values are supported with SunSpec.
I am using the “normal” modbus pofile from SMA.
The configuration I also copied form other topics in the forum here. This should also fit for you I think. You just have to rename them (.items, .things, .sitemap) and put them into configuration folder. Set the right IP in the things file.
sma_items.txt (5.7 KB)
sma_things.txt (4.5 KB)
Wechselrichter_sitemap.txt (1.3 KB)
Also you need to install the Javascript traformation service and put them into “transform” folder. Rename them also to “.js”.
smalimit.txt (84 Bytes)
smalimit100.txt (89 Bytes)
smalimit100A.txt (96 Bytes)
smalimit1000.txt (90 Bytes)
Hope this helps. BR
