Frankly, I have no idea.
As ssen above on one of your screenshots, the degree sign did sometimes show up.
I noticed another thread with the same problem, also on a windows machine, not solved yet either!
Hello, I had the same problem,
after 1-2 restarts it was done.
PS: Don’t forget the clean cache!
salute
oliver
Thank Oliver, Can you please guide me through the process to clean the cache? Only know the PI commands.
Many thanks
From the command line use these commands.
sudo systemctl stop openhab2
sudo openhab-cli clean-cache
sudo systemctl start openhab2 or sudo reboot
I’m running windows. Thanks though.
Windows does not have the Karaf console?
You will need to stop OH first then use openhab-cli clean-cache.
