Looks like I am seeing a similar disconnect behaviour with 2.5.0.M4…
Out of the blue the OH paho client disconnects:
2019-10-26 07:05:16.368 [hingStatusInfoChangedEvent] - 'mqtt:broker:mosquitto' changed from UNINITIALIZED to INITIALIZING
2019-10-26 07:05:16.546 [hingStatusInfoChangedEvent] - 'mqtt:broker:mosquitto' changed from INITIALIZING to OFFLINE
2019-10-26 07:05:17.650 [hingStatusInfoChangedEvent] - 'mqtt:broker:mosquitto' changed from OFFLINE to ONLINE
2019-10-26 07:05:17.673 [me.event.ThingUpdatedEvent] - Thing 'mqtt:broker:mosquitto' has been updated.
2019-10-26 07:05:23.320 [hingStatusInfoChangedEvent] - 'mqtt:topic:mosquitto:dsmr' changed from UNINITIALIZED to INITIALIZING
2019-10-26 07:05:23.554 [hingStatusInfoChangedEvent] - 'mqtt:topic:mosquitto:dsmr' changed from INITIALIZING to ONLINE
2019-10-26 09:13:36.885 [hingStatusInfoChangedEvent] - 'mqtt:broker:mosquitto' changed from ONLINE to OFFLINE
2019-10-26 09:13:36.891 [hingStatusInfoChangedEvent] - 'mqtt:topic:mosquitto:dsmr' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-10-26 09:13:36.892 [hingStatusInfoChangedEvent] - 'mqtt:broker:mosquitto' changed from ONLINE to OFFLINE
2019-10-26 09:13:36.903 [me.event.ThingUpdatedEvent] - Thing 'mqtt:broker:mosquitto' has been updated.
2019-10-26 09:13:37.217 [hingStatusInfoChangedEvent] - 'mqtt:broker:mosquitto' changed from OFFLINE to ONLINE
2019-10-26 09:13:37.219 [hingStatusInfoChangedEvent] - 'mqtt:topic:mosquitto:dsmr' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2019-10-26 09:13:37.226 [me.event.ThingUpdatedEvent] - Thing 'mqtt:broker:mosquitto' has been updated.
And openhab.log
2019-10-26 07:04:44.530 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mqtt.things'
2019-10-26 07:05:16.679 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.2.2' with clientid paho38132086163237 and file store '/openhab/userdata/mqtt/192.168.2.2'
2019-10-26 09:13:36.808 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'mqtt.things'
2019-10-26 09:13:36.895 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.2.2' with clientid paho45832498899654 and file store '/openhab/userdata/mqtt/192.168.2.2'
The mosquitto.log
2019-10-26T07:04:16: mosquitto version 1.6.7 starting
2019-10-26T07:04:16: Config loaded from /mosquitto/config/mosquitto.conf.
2019-10-26T07:04:16: Opening ipv4 listen socket on port 1883.
2019-10-26T07:04:16: Opening ipv6 listen socket on port 1883.
2019-10-26T07:04:16: New connection from 192.168.2.87 on port 1883.
2019-10-26T07:04:16: New client connected from 192.168.2.87 as dsmrv4 (p2, c1, k15, u'**redacted**').
2019-10-26T07:04:16: No will message specified.
2019-10-26T07:04:16: Sending CONNACK to dsmrv4 (0, 0)
2019-10-26T07:05:08: Received PUBLISH from dsmrv4 (d0, q0, r1, m0, 'sensor/dsmr', ... (315 bytes))
2019-10-26T07:05:16: Received PINGREQ from dsmrv4
2019-10-26T07:05:16: Sending PINGRESP to dsmrv4
2019-10-26T07:05:16: New connection from 172.18.0.1 on port 1883.
2019-10-26T07:05:17: New client connected from 172.18.0.1 as paho38132086163237 (p2, c1, k60000, u'moerman').
2019-10-26T07:05:17: No will message specified.
2019-10-26T07:05:17: Sending CONNACK to paho38132086163237 (0, 0)
2019-10-26T07:05:23: Received SUBSCRIBE from paho38132086163237
2019-10-26T07:05:23: homeassistant/# (QoS 0) 2019-10-26T07:05:23: Sending SUBACK to paho38132086163237
2019-10-26T07:05:23: sensor/dsmr (QoS 0)
2019-10-26T07:05:23: Sending PUBLISH to paho38132086163237 (d0, q0, r1, m0, 'sensor/dsmr', ... (315 bytes))
2019-10-26T09:13:28: Received PINGREQ from dsmrv4
2019-10-26T09:13:28: Sending PINGRESP to dsmrv4
2019-10-26T09:13:34: Received PUBLISH from dsmrv4 (d0, q0, r1, m0, 'sensor/dsmr', ... (315 bytes))
2019-10-26T09:13:34: Sending PUBLISH to paho38132086163237 (d0, q0, r0, m0, 'sensor/dsmr', ... (315 bytes))
2019-10-26T09:13:36: Received UNSUBSCRIBE from paho38132086163237
2019-10-26T09:13:36: homeassistant/#
2019-10-26T09:13:36: Sending UNSUBACK to paho38132086163237
2019-10-26T09:13:36: sensor/dsmr
2019-10-26T09:13:36: +/+/$homie
2019-10-26T09:13:36: Received DISCONNECT from paho38132086163237
2019-10-26T09:13:36: Client paho38132086163237 disconnected.
2019-10-26T09:13:36: New connection from 172.18.0.1 on port 1883.
2019-10-26T09:13:37: New client connected from 172.18.0.1 as paho45832498899654 (p2, c1, k60000, u'**redacted***').
2019-10-26T09:13:37: No will message specified.
2019-10-26T09:13:37: Sending CONNACK to paho45832498899654 (0, 0)
2019-10-26T09:13:43: Received PINGREQ from dsmrv4
2019-10-26T09:13:43: Sending PINGRESP to dsmrv4
2019-10-26T09:13:58: Received PINGREQ from dsmrv4
2019-10-26T09:13:58: Sending PINGRESP to dsmrv4
2019-10-26T09:14:13: Received PINGREQ from dsmrv4
2019-10-26T09:14:13: Sending PINGRESP to dsmrv4
2019-10-26T09:14:24: Received PUBLISH from dsmrv4 (d0, q0, r1, m0, 'sensor/dsmr', ... (315 bytes))
So, after a short disconnect from OH (don’t know why…), it reconnects but does not respond to the CONNACK from Mosquitto anymore…
