Well that turned out to be useless. Instead, I’m going back with building an Ubuntu box with openHAB and Plex Media Server and some kind of NAS or RAID setup. I found a few places that have mini-ITX boards, and through more searching, I found I can get a power supply that runs off the DC power of a car battery. Some have regulators that turn the computer on when the ignition is turned on, but I don’t need that. I figure I’ll have it hooked into the batteries directly, and once we get solar, that computer should run all the time then. Its only a 120 Watt power supply, they make some that are 160W, but that is hopefully enough. Not like it will have a huge power hungry graphics card or anything like that.
Now then, I found a Z-Wave USB adapter. Figure I need that to talk to the Z-Wave devices. But what about everything else? Do I also need Bluetooth and Wifi? I’m not sure how other devices communicate with openHAB. I don’t have anything yet, so I can’t test it out, but I’m trying to figure out how to make it all work before I start aimlessly buying parts. Getting Bluetooth isn’t that difficult, I can easily get a USB adapter for that as well. I’ll also be plugging the openHAB computer into the network over ethernet, but it will be connected to the wifi through a switch, so I assume it should be able to connect to anything that uses Wifi then. Is this right? I don’t want to have to buy a bunch of different dongles for every other type of protocol that may come up, but I want to have options as well.
