Hello Everyone,
My name is Jose Luis this is my first post in here. I am new over Home Automation.
As I am from Argentina, I do not have all the money to spend in this but as i am enthusiastic, I really really want to do it.
I want to buy touch wall switches, I have found a lot of them in Aliexpress, but most of them has their own app.
Like:
Note that these require neutral as well as as live. In countries such as UK, South Africa and many others, this is not normal… Replacing your existing ones for these option’s might not be possible. Double check before you buy that you have neutral.
If these are wifi - and it seems they are - you can probably put your own custom firmware on as they’ll use something like esp8266. Espurna is my favourite starting point. Buy one and experiment?
Hi Cripin,
I’m in the same position as Jouse in that I have just made a start with Openhab.
I have just fitted one of these WiFi dimmer switches but would like to use Openhab rather than the app. Could you (or anybody else) give a bit more information on the steps needed to get going.
https://www.ebay.co.uk/itm/123045952612Yes
it has a neutral connection. All up and running with app and manual operation.
I just need to work out where to go from here. I guess I need to work out what binding to use??
So what is the brand? You need to see if it has an http api or mqtt subscriber. If it has either of those then you should be good.
If not, you will have to work out the protocol yourself with a sniffer.
The Lanbon switches use the internet to talk to servers in China, but there is also a LAN mode. It isn’t publicly documented. I have been reverse engineering the LAN protocol with some (but not complete) success. My solution, to my knowledge, only works with the three switches I have, but hopefully would work with more. I don’t have any more switches to test and no others have tested it yet. I have Java and Python code. It is at Lanbon light switches. The doco is Open Content, the code is under a BSD license. Feel free to use - but even better, send me any feedback you have! Best is solutions to the outstanding issues!
