is there a platform specific download ( Linux 64bit ) for the 0.9 release?
I only find 0.8 releases here:
layout: documentation
{% include base.html %}
# Downloads
## Source Code
The source code of Eclipse SmartHome™ is available in our [GitHub repository](https://github.com/eclipse/smarthome).
## Binary Artifacts
Since Eclipse SmartHome™ is not a solution by itself, we do not offer any ready-to-run downloadable artifact. The binary build of Eclipse SmartHome [consists out of OSGi bundles](../features/index.html) that are provided through p2 and Maven repositories.
Besides the runtime bundles, Eclipse SmartHome comes with the "Designer", which is an Eclipse RCP application. The Designer is a tool for textual configuration of a runtime. You only need it, if your solution makes use of the [textual configuration support](../features/dsl.html) of Eclipse SmartHome.
### Releases
This file has been truncated. show original
Marco
sihui
(SiHui)
January 15, 2018, 11:13am
#2
The ESH is deprecated, please use Visual Studio Code with openHAB plugin:
https://docs.openhab.org/configuration/editors.html
Really? Is that not M$ technology???
Uff…
sihui
(SiHui)
January 15, 2018, 11:23am
#4
I guess you have no choice
But there is a Linux version available …
Thanks for clarification. I’ll try it out.
Dibbler42
(Thomas Bail)
January 15, 2018, 1:23pm
#6
No that has nothing to do with MS. Just check it out it is much better than the designer
Yes and no. It was initiated by microsoft, but is completeley free and open source.
It’s based on the same framework (electron) like the atom ide and has not much in common with their other products than the name “visual studio”.
