Really dumb question. …
How do I start smarthime designer on rpi?
Not at all. You run it on your desktop and should access the config files on your rpi through a samba share (or copying them over manually once you are done with editing).
i noticed the .exe after i installed, which led me to believe it was Windows based. thanks Kai
any way to run designer off usb flash drive?
