SmartHome/J - Amazon Echo Control Binding
@J-N-K I am seeing devices go on/off line every 4 minutes or so. There is an error in the HttpRequestBuilder. I didn’t include the header given its size. I am running 4.3.0.M4 Milestone build.
	at org.smarthomej.binding.amazonechocontrol.internal.util.HttpRequestBuilder$Builder.lambda$0(HttpRequestBuilder.java:265) ~[?:?]
	at org.smarthomej.binding.amazonechocontrol.internal.util.HttpRequestBuilder$HttpResponseListener.onComplete(HttpRequestBuilder.java:364) [bundleFile:?]
another error in the logs.
2024-11-23 11:36:14.872 [WARN ] [rol.internal.util.HttpRequestBuilder] - Parsing json failed: false
com.google.gson.JsonSyntaxException: com.google.gson.stream.MalformedJsonException: Unterminated string at line 1 column 2096452 path $.networkDetail
	at com.google.gson.Gson.fromJson(Gson.java:1241) ~[?:?]
	at com.google.gson.Gson.fromJson(Gson.java:1137) ~[?:?]
	at com.google.gson.Gson.fromJson(Gson.java:1047) ~[?:?]
	at java.util.concurrent.CompletableFuture$UniApply.tryFire(CompletableFuture.java:646) [?:?]
	at java.util.concurrent.CompletableFuture.postComplete(CompletableFuture.java:510) [?:?]
	at java.util.concurrent.CompletableFuture.complete(CompletableFuture.java:2147) [?:?]
	at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:218) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:210) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:481) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:461) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.client.HttpReceiver.access$1100(HttpReceiver.java:73) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.client.HttpReceiver$Decoder.decode(HttpReceiver.java:807) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.client.HttpReceiver$Decoder.decode(HttpReceiver.java:768) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.client.HttpReceiver$Decoder.access$600(HttpReceiver.java:744) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.client.HttpReceiver.decodeResponseContent(HttpReceiver.java:386) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.client.HttpReceiver.responseContent(HttpReceiver.java:354) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.content(HttpReceiverOverHTTP.java:332) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.http.HttpParser.parseContent(HttpParser.java:1841) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1552) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.parse(HttpReceiverOverHTTP.java:208) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:148) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:80) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:172) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.54.v20240208]
Caused by: com.google.gson.stream.MalformedJsonException: Unterminated string at line 1 column 2096452 path $.networkDetail
	at com.google.gson.stream.JsonReader.syntaxError(JsonReader.java:1659) ~[?:?]
	at com.google.gson.stream.JsonReader.nextQuotedValue(JsonReader.java:1044) ~[?:?]
	at com.google.gson.stream.JsonReader.nextString(JsonReader.java:826) ~[?:?]
	at com.google.gson.internal.bind.TypeAdapters$15.read(TypeAdapters.java:421) ~[?:?]
	at com.google.gson.internal.bind.TypeAdapters$15.read(TypeAdapters.java:409) ~[?:?]
	at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$1.readIntoField(ReflectiveTypeAdapterFactory.java:212) ~[?:?]
	at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$FieldReflectionAdapter.readField(ReflectiveTypeAdapterFactory.java:433) ~[?:?]
	at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:393) ~[?:?]
	at com.google.gson.Gson.fromJson(Gson.java:1227) ~[?:?]
	... 40 more
Unfortunately I don’t have time at the moment to work on openHAB. I’m very busy with business issues.
:+1:
