Hi Community, hi @rogrun,
I am facing issues with the viessmann binding from SmarthomeJ since yesterday afternoon about 2pm. That was the time of the last successfull API call that returned thedata. Since then I just see the following in the log:
2023-05-29 14:08:45.370 [WARN ] [ernal.handler.ViessmannBridgeHandler] - Parsing Viessmann response fails: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was BEGIN_ARRAY at line 1 column 11142 path $.data[22].properties.entries.value
2023-05-29 14:13:10.934 [WARN ] [ernal.handler.ViessmannBridgeHandler] - Parsing Viessmann response fails: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was BEGIN_ARRAY at line 1 column 11142 path $.data[22].properties.entries.value
2023-05-29 14:17:36.292 [WARN ] [ernal.handler.ViessmannBridgeHandler] - Parsing Viessmann response fails: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was BEGIN_ARRAY at line 1 column 11142 path $.data[22].properties.entries.value
and so on…
This was still the case today evening so I tried to check what is going wrong. I noticed then, that there is Version 3.2.16 already available (I was using 3.2.15). So I updated the binding and since then, the device is not getting online. It stays in status “INITIALIZING”. The bridge is “ONLINE”
I set the loglevel to DEBUG, but I just see:
2023-05-30 19:23:40.745 [DEBUG] [n.internal.ViessmannDiscoveryService] - Discovered Device viessmann:device:0fe60539bc:TCU
2023-05-30 19:23:55.745 [DEBUG] [n.internal.ViessmannDiscoveryService] - Discovered Device viessmann:device:0fe60539bc:0
2023-05-30 19:23:55.746 [DEBUG] [n.internal.ViessmannDiscoveryService] - Discovered Device viessmann:device:0fe60539bc:RoomControl-1
2023-05-30 19:23:55.747 [DEBUG] [n.internal.ViessmannDiscoveryService] - Discovered Device viessmann:device:0fe60539bc:TCU
2023-05-30 19:24:10.748 [DEBUG] [n.internal.ViessmannDiscoveryService] - Discovered Device viessmann:device:0fe60539bc:0
2023-05-30 19:24:10.749 [DEBUG] [n.internal.ViessmannDiscoveryService] - Discovered Device viessmann:device:0fe60539bc:RoomControl-1
2023-05-30 19:24:10.749 [DEBUG] [n.internal.ViessmannDiscoveryService] - Discovered Device viessmann:device:0fe60539bc:TCU
2023-05-30 19:24:25.750 [DEBUG] [n.internal.ViessmannDiscoveryService] - Discovered Device viessmann:device:0fe60539bc:0
2023-05-30 19:24:25.751 [DEBUG] [n.internal.ViessmannDiscoveryService] - Discovered Device viessmann:device:0fe60539bc:RoomControl-1
No errors.
Can anybody help me what is going on here?
Dieter
