I am using Openhab 3.2 in windows 10 and trying to integrate with Smartthings.
I have followed all the instructions to setup the device handler and smart app in smartthings. I am using the 3.2 smartthings binding.
When scanning for things using the smartthings binding I set 1 thing to be discovered. It worked. Then I went back to the smart app and added a few more things and scanned again from Openhab. The thing that had before been discovered was erased and nothing else appeared.
I believe this is the second time it has done this and the only way to get it to work was to delete the device handler and smart app in the samsung smartthings site and start from scratch.
Has anyone seen this behavior before and knows how to fix this?
Thank you
Carlos
