pi@raspberrypi:~/www $ sudo apt-get purge openhab2*
Reading package lists... Done
Building dependency tree
Note, selecting 'openhab2' for regex 'openhab2*'
Note, selecting 'openhab2-addons' for regex 'openhab2*'
Note, selecting 'openhab2-offline' for regex 'openhab2*'
Note, selecting 'openhab2-online' for regex 'openhab2*'
Note, selecting 'openhab2-addons-legacy' for regex 'openhab2*'
Package 'openhab2-online' is not installed, so not removed
Package 'openhab2-addons' is not installed, so not removed
Package 'openhab2-addons-legacy' is not installed, so not removed
Package 'openhab2' is not installed, so not removed
The following packages will be REMOVED:
openhab2-offline*
And here is the problem:
pi@raspberrypi:~/www $ sudo apt-get install openhab2-offline
openhab2-offline is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
And here is my concern regarding the remove current version
openhab2-offline
The following NEW packages will be installed:
openhab2
0 upgraded, 1 newly installed, 1 to remove and 0 not upgraded.
So the question is how to smoothly update my current OH2? And save ALL settings?
If you sudo apt-get install openhab2, it will retain your existing configs and do a smooth installation over the existing openhab2-offline version (it will remove it).
apt-get remove openhab2-offline will keep your files and directories (this is what the installation script is doing) apt-get purge openhab2-offline will remove everything (don’t do purge )
pi@raspberrypi:~ $ sudo apt-get install openhab2
openhab2-offline
openhab2
Need to get 53.2 MB of archives.
After this operation, 129 MB disk space will be freed.
Do you want to continue? [Y/n] Y
Get:1 http://dl.bintray.com/openhab/apt-repo2/ unstable/main openhab2 all 2.1.0~20170129232652-1 [53.2 MB]
Fetched 53.2 MB in 36s (1,454 kB/s)
(Reading database ... 35190 files and directories currently installed.)
Removing openhab2-offline (2.0.0~20161218105629) ...
Processing triggers for systemd (215-17+deb8u6) ...
Selecting previously unselected package openhab2.
(Reading database ... 33262 files and directories currently installed.)
Preparing to unpack .../openhab2_2.1.0~20170129232652-1_all.deb ...
Unpacking openhab2 (2.1.0~20170129232652-1) ...
Setting up openhab2 (2.1.0~20170129232652-1) ...
I don’t think so… In theory, the new openhab2 package deployed the new versions of the addons that you were using and had defined in the /etc/openhab2/services/addons.cfg file.
