I can see if I can fix that, didn’t have time for a pull request yet, in the mean time I enabled the issue tracker on my repo Issues · esdeboer/openhab2-addons · GitHub
If you could post the log of the error here, or make an issue I can see if it is a quick fix
time has come - my openhab upgraded to 4.0 something. In fact the good 3.1 jar from above is loaded and active but it does not work: no server or clients are reachable. I would guess its caused by some interface changes? Is anyone able to upgrade this addon?
Anyone else with this Problem? I would step into the code but I could not get the java environment running - is there a openhab addon-development docker out there?
(as thread title is snapcast binding I continue this conversation)
Hi all, I am also in the process of moving to 4.0 and realized snapcast binding is not working. @esdeboer If there is anything I can do to fasciliate let me know.
many thanks @esdeboer for sharing.
I downloaded, extracted to /usr/share/openhab/addons/, restarted but it is not showing up when I want to create a new thing from UI. bundle:list says 4.0.2 is properly loaded.
ID │ State │ Lvl │ Version │ Name
270 │ Active │ 80 │ 4.0.2 │ openHAB Add-ons :: Bundles :: Snapcast Binding
The reason it wasn’t showing up in the UI was a config file was changed in OH4, I’ve updated the snapcast binding, now it should also show up in the openHab UI.
