(Solved) Snapshot #1728, no advanced settings in HABmin & ERROR 500 in paper ui for zwave things
Definitely not an issue in S1725
I also can confirm both errors with snapshot 1728. I have exactly the same issues. The only difference: Advanced settings of z-wave controller are shown. For all other z-wave devices, they are not displayed.
@chris Did you already notice that?
No - I’d not seen this. I’m not sure why the advanced settings would be gone. I don’t think that anything has changed in HABmin (I’ve certainly not changed anything).
Is PaperUI the same (I guess so)?
I could guess that this is may be due to a change in the core, or maybe a change in the binding, although I don’t think there have been any.
Can someone provide any logs if there are exceptions? I’ve very little time at the moment unfortunately.
There was a change of the core here, but I don’t know if this has to do anything with this issue??
Edit: Nothing in the log files!
Doesn’t look like it should cause an issue, but I just looked at the binding, and there have been no changes there at all since I fixed a database problem, and after that change everyone said it was working.
There have been no changes in the binding since.
@chris
So it seems occur after snapshot 1725.
Habmin and PaperUI don‘t use the Jackson or swagger feature. I doubt it has any connection. And REST works better than before.
I’m not really sure then. I had multiple reports that the last database update fixed a previous issue and there have been no changes since.
Unfortunately I’ve got no time at the moment as I have other (non-openHAB) work to do. If someone can work out what’s going on, then I can try and look at it, but I really can’t spend a lot of time looking at this right now.
Did you try cleaning cache? (OpenHAB AND Browser Cache)
Yes, both. Same problems…
I’ve updated to snapshot 1729 now, but the problems are still existing.
Do I need ZWAVE devices to reproduce the problem?
Unfortunately yes. You only can add a controller manually. But the other devices are stored in controller.
Can you try raising the log level of Jersey so it shows the stacktrace of the exception resulting in the 500 error?
log:set trace org.glassfish.jersey.server
@J-N-K
PaperUI error: 'Internal Server Error’ (500:SERVER_ERROR)
2019-10-19 14:18:04.067 [DEBUG] [ersey.server.ServerRuntime$Responder] - Starting mapping of the exception.
org.glassfish.jersey.server.internal.process.MappableException: java.lang.NullPointerException
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.mapTargetToRuntimeEx(AbstractJavaResourceMethodDispatcher.java:179) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.access$200(AbstractJavaResourceMethodDispatcher.java:72) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:149) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [128:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [128:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [128:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [125:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [125:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [125:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [125:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [125:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [23:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:873) [93:org.eclipse.jetty.servlet:9.4.18.v20190429]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:542) [93:org.eclipse.jetty.servlet:9.4.18.v20190429]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [197:org.ops4j.pax.web.pax-web-jetty:7.2.10]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) [92:org.eclipse.jetty.server:9.4.18.v20190429]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [90:org.eclipse.jetty.security:9.4.18.v20190429]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) [92:org.eclipse.jetty.server:9.4.18.v20190429]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) [92:org.eclipse.jetty.server:9.4.18.v20190429]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1700) [92:org.eclipse.jetty.server:9.4.18.v20190429]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) [92:org.eclipse.jetty.server:9.4.18.v20190429]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1345) [92:org.eclipse.jetty.server:9.4.18.v20190429]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [197:org.ops4j.pax.web.pax-web-jetty:7.2.10]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) [92:org.eclipse.jetty.server:9.4.18.v20190429]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:480) [93:org.eclipse.jetty.servlet:9.4.18.v20190429]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1667) [92:org.eclipse.jetty.server:9.4.18.v20190429]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) [92:org.eclipse.jetty.server:9.4.18.v20190429]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1247) [92:org.eclipse.jetty.server:9.4.18.v20190429]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) [92:org.eclipse.jetty.server:9.4.18.v20190429]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [197:org.ops4j.pax.web.pax-web-jetty:7.2.10]
	at org.eclipse.jetty.server.Server.handle(Server.java:505) [92:org.eclipse.jetty.server:9.4.18.v20190429]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:370) [92:org.eclipse.jetty.server:9.4.18.v20190429]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:267) [92:org.eclipse.jetty.server:9.4.18.v20190429]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305) [83:org.eclipse.jetty.io:9.4.18.v20190429]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [83:org.eclipse.jetty.io:9.4.18.v20190429]
	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [83:org.eclipse.jetty.io:9.4.18.v20190429]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [95:org.eclipse.jetty.util:9.4.18.v20190429]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [95:org.eclipse.jetty.util:9.4.18.v20190429]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [95:org.eclipse.jetty.util:9.4.18.v20190429]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [95:org.eclipse.jetty.util:9.4.18.v20190429]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [95:org.eclipse.jetty.util:9.4.18.v20190429]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:698) [95:org.eclipse.jetty.util:9.4.18.v20190429]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:804) [95:org.eclipse.jetty.util:9.4.18.v20190429]
Caused by: java.lang.NullPointerException
	at org.eclipse.smarthome.io.rest.core.config.EnrichedConfigDescriptionParameterDTO.<init>(EnrichedConfigDescriptionParameterDTO.java:52) ~[?:?]
	at org.eclipse.smarthome.io.rest.core.config.EnrichedConfigDescriptionDTOMapper.mapEnrichedParameters(EnrichedConfigDescriptionDTOMapper.java:59) ~[?:?]
	at org.eclipse.smarthome.io.rest.core.config.EnrichedConfigDescriptionDTOMapper.map(EnrichedConfigDescriptionDTOMapper.java:45) ~[?:?]
	at org.eclipse.smarthome.io.rest.core.internal.config.ConfigDescriptionResource.getByURI(ConfigDescriptionResource.java:110) ~[?:?]
	at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[?:?]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[?:?]
	... 54 more
2019-10-19 14:18:04.081 [DEBUG] [ersey.server.ServerRuntime$Responder] - Exception 'null' has been mapped by 'org.eclipse.smarthome.io.rest.JSONResponse$ExceptionMapper' to response 'Internal Server Error' (500:SERVER_ERROR).
That looks like level DEBUG. Level TRACE may give even more useful information.
log:get
org.glassfish.jersey.server             │ TRACE
It is set to TRACE!
Thanks we should be able to fix this NPE. :slight_smile:
The EnrichedConfigDescriptionDTOMapper was introduced with:
@wborn
But it was merged on 14.10.2019, 12:51, and snapshot 1725 was build on 15.10.2019, 5:55. ??
And snapshot 1725 has allegedly not this error! Maybe it was merged later (after 1725)?
