OH2 Snapshot 2.3.0 #1225
Trying to get someones attention regarding this matter.
This thread has been silent for a while, but the problem is still there.
Literately hundreds of these lines are spewed out if any browsers are connected to any of the WEB pages.
Goes like this:
org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [84:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [84:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [84:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [84:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [84:org.eclipse.jetty.util:9.3.22.v20171030]
Caused by: org.eclipse.jetty.io.EofException
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:199) ~[73:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:420) ~[73:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.WriteFlusher.completeWrite(WriteFlusher.java:375) ~[73:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectChannelEndPoint$3.run(SelectChannelEndPoint.java:107) ~[73:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectChannelEndPoint.onSelected(SelectChannelEndPoint.java:193) ~[73:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.ManagedSelector$SelectorProducer.processSelected(ManagedSelector.java:283) ~[73:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.ManagedSelector$SelectorProducer.produce(ManagedSelector.java:181) ~[73:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:249) ~[84:org.eclipse.jetty.util:9.3.22.v20171030]
... 5 more
Caused by: java.io.IOException: Broken pipe
at sun.nio.ch.FileDispatcherImpl.write0(Native Method) ~[?:?]
at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47) ~[?:?]
at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93) ~[?:?]
at sun.nio.ch.IOUtil.write(IOUtil.java:51) ~[?:?]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:471) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:177) ~[73:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jet
Any help is greatly appreciated.
It been like this for quite some weeks now.
Have tried to delete the contents of /var/lib/openhab2/cache and /var/lib/openhab2/tmp. No joy.
Everything else is working fine.
Cheers
