Hello folks!
I have problems with restdocs!
I’ve tried latest snapshot #1715 on several “Windows 10, 64 bit” machines. I’ve installed all from scratch.
I’ve tested several times on the same machine. One installation was successful and two installations failed. On a second Win 10 (64 bit) PC the same problem (one successfull, one failed).
If failed, all have the same errors:
Here are the errors, when I open “REST API Documentation”:
500 : <html> <head> <meta http-equiv="Content-Type" content="text/html;charset=utf-8"/> <title>Error 500 Request failed.</title>
</head> <body><h2>HTTP ERROR 500</h2> <p>Problem accessing /rest/swagger.json. Reason: <pre> Request failed.</pre></p><hr>
<a href="http://eclipse.org/jetty">Powered by Jetty:// 9.4.18.v20190429</a><hr/> </body> </html>
http://localhost:8080/rest/swagger.json
13:40:18.161 [WARN ] [org.eclipse.jetty.server.HttpChannel ] - /rest/swagger.json
javax.servlet.ServletException: javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: Could not initialize class io.swagger.converter.ModelConverters
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.Server.handle(Server.java:505) ~[89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:370) [89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:267) [89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305) [80:org.eclipse.jetty.io:9.4.18.v20190429]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [80:org.eclipse.jetty.io:9.4.18.v20190429]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [80:org.eclipse.jetty.io:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [92:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [92:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [92:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [92:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [92:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:698) [92:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:804) [92:org.eclipse.jetty.util:9.4.18.v20190429]
at java.lang.Thread.run(Unknown Source) [?:?]
Caused by: javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: Could not initialize class io.swagger.converter.ModelConverters
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) ~[?:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) ~[?:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:873) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:542) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) ~[?:?]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1700) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1345) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:480) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1667) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1247) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
... 15 more
Caused by: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: Could not initialize class io.swagger.converter.ModelConverters
at org.glassfish.jersey.servlet.internal.ResponseWriter.rethrow(ResponseWriter.java:278) ~[?:?]
at org.glassfish.jersey.servlet.internal.ResponseWriter.failure(ResponseWriter.java:260) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:509) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:334) ~[?:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) ~[?:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[?:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[?:?]
... 15 more
Caused by: java.lang.NoClassDefFoundError: Could not initialize class io.swagger.converter.ModelConverters
at io.swagger.jaxrs.Reader.parseMethod(Reader.java:798) ~[?:?]
at io.swagger.jaxrs.Reader.read(Reader.java:299) ~[?:?]
at io.swagger.jaxrs.Reader.read(Reader.java:145) ~[?:?]
at io.swagger.jaxrs.listing.BaseApiListingResource.scan(BaseApiListingResource.java:56) ~[?:?]
at io.swagger.jaxrs.listing.BaseApiListingResource.process(BaseApiListingResource.java:101) ~[?:?]
at io.swagger.jaxrs.listing.BaseApiListingResource.getListingJsonResponse(BaseApiListingResource.java:147) ~[?:?]
at io.swagger.jaxrs.listing.ApiListingResource.getListing(ApiListingResource.java:32) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Unknown Source) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[?:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[?:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[?:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) ~[?:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[?:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[?:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[?:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) ~[?:?]
... 15 more
