i am new to openhab2 and I want to get data via snap from my synology disk station.
I installed snmp on the raspberry where openhab runs on. On the raspberry (terminal) I can successfully get snap data from the device, but on the openhab log I get “2018-03-26 17:18:51.108 [ERROR] [ab.binding.snmp.internal.SnmpBinding] - SNMP: snmp not initialised - aborting request”
I tried everything I found here in the community, but it doesn’t work.
The port in the openhab snap config is 162. Trapd config forwards to 162.
Does anyone has an idea?
Is OH installed on the same NAS? If not then can you try an snmpwalk from the OH server. We need to find out if you have a connectivity issue or a configuration issue.
Does this mean your problem has been resolved? If so then please mark this thread as being resolved, this is to help others who may find this thread from a search.
When starting open hab Server i get the following error in the openhab logfile:
SNMP Binding couldn‘t listen to 0.0.0.0/162
Does anyone know why this error occures and Howe to solve it?
Regards
Sven
So I have solvent the problem! The Problem was the Port 162 in the snmp config. I changed it to 1600 there and added the Port also to the snmptrap.conf. And now it works fine.
